I am facing problem in I/O Interrupt for waveform record in the asyn. If the value of waveform record change very fast then some of the samples missing or same sample repeat twice even if before p_interruptInt32Array->callback () function the value is scanned properly by driver. But i think the read value is pushed to the callback but it is not handle that much fast in the callback. I checked the code for interruptCallbackInput in devAsynXXXArray.h. In devAsynXXXArray.c dbScanUnlock has been used before scanIoRequest(). Can it create problem for repeating same value? My assumption is as dbScanUnlock and before scanIoRequest() execute, value change and second time triggers interrupt. This result same value for both interrupts. I checked interrupt callback code in devAsynInt32.c where epicsMutexUnlock has been used after scanIoRequest(). Thank you Vishnu
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
