1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Epics/Raspberry Pi data acquisition
To: Steve Shoaf <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Fri, 21 Feb 2014 11:02:09 -0800
Sweet!
There are a lot of development in this embedded arena.
Intel is becoming very aggressive in relation to ARM.
Of course, you may have heard of the galileo board (x86 arch)
http://www.intel.com/content/www/us/en/intelligent-systems/galileo/galileo-overview.html
but that's so 2013!
At the last CES, Intel announced major initiatives in the embedded arena, including a SD card sized computer
http://www.intel.com/content/www/us/en/do-it-yourself/edison.html
Given that Altera FPGAs are now built in Intel's 22nm foundries, it is easy to imagine that a combo Intel core + altera FPGA could soon see the day. Well, keep on watching.
E
Subject: Re: Epics/Raspberry Pi data acquisition
Date: Fri, 21 Feb 2014 11:16:11 -0600
To: [email protected]
CC: [email protected]
Emmanuel,
Altera has had similar SoC offerings for quite some time just like Xilinx.  Terasic makes an Altera board (DE1-SoC Board $199) similar to the Zedboard.
We've ordered a NOVSOM CV system module board from Novtech that has a complete Altera SoC system on a module so you don't need to design the complicated FPGA or DDR interfaces on your own circuit board.  They currently have the Altera Cyclone V SoC available and are working on an Altera Arria V SoC product.  The NOVSOM AV board to board (B2B) pinout is identical to the NOVSOM CV allowing users to easily switch between Arria V SoC and Cyclone V SoC on the same base board.
Steve
On Feb 20, 2014, at 5:41 PM, Emmanuel Mayssat <[email protected]> wrote:
Thanks John,
The past year, I left my RaspPi and Beagleboard in the drawer and started playing with the papilio board
http://papilio.cc/.You probably want to have a look at it! This solution is probably better than what you have + you won't have to deal with the missing ~ $20 FTDI.
Ultimately I have my eyes on the Xilinx ZynQ
http://zedboard.org/
http://www.xilinx.com/training/zynq/index.htm
which offer the combination ARM + FPGA for ~ $400 / dev board
which is certainly more expensive than the RaspPi+FPGA solution, but more flexible and higher performance. I also predict that Intel + Altera will offer a similar SOC soon.
In the same space, I am looking at PoE and Qt Embedded.
Check this out
http://www.megaleecher.net/Raspberry_Pi_POE#axzz2tuLQEoyv
http://www.ics.com/blog/building-qt-and-qtwayland-raspberry-pi#.UwaOhsv8NhF
https://gitorious.org/raspberry-qt/raspberry-qt/source/3c2ed05270137644300cde3b22829380698ff9a9:README.txt
Now imagine that you plug your embedded IOC, PVs are available but GUI are also deployed on a distributed file-system.
Cheers,
E
In the end I was, with relatively little work, able to write some HDL code for the FPGA, program the FPGA from the Pi over the USB connection, and then connect an IOC on the Pi to the FPGA via the USB connection, thus creating  a simple stand alone data acquisition instrument with built-in IOC.
RE: Epics/Raspberry Pi data acquisition Hill, Jeff
Epics/Raspberry Pi data acquisition John Dobbins
RE: Epics/Raspberry Pi data acquisition Emmanuel Mayssat
Re: Epics/Raspberry Pi data acquisition Steve Shoaf
Prev: Waveform record I/O interrupt. asyn Vishnu Patel
Next: RE: Epics/Raspberry Pi data acquisition Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Epics/Raspberry Pi data acquisition Steve Shoaf
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
