Subject: |
Re: Monitoring whether an IP device is connected or not |
Ralph Lange <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Tue, 25 Feb 2014 13:33:07 +0100 |
On 25.02.2014 13:22, David Michel wrote:
Hi All,
I have a device with an IP (i.e. a computer on the network which then
talks to other devices, but we'd like to treat it as a black box) and
I'd like to be able to do a "pulse check" from an IOC running on
another machine to detect whether it's still running or not.
Just as a quick test, I wrote a quick C function that performs a
'ping' and hooked that up to an aSub record. That works fine but, as
you can imagine, it's obviously very slow and keeps the device busy
responding to ping calls all the time, so it's not very practical at
all.... there must be a better way!
Now, EPICS itself does this pulsecheck somehow as can be observed when
shutting down an IOC where others IOCs that depend on it will rather
quickly notify of this connection loss on the iocshell, or with OPIs
screens suddenly showing widgets as disconnected.
Wondering how this is done and how I can apply it to my case. Any
ideas most welcome.
All IOCs are sending UDP broadcasts (alive beacons) every 15 seconds
(default, configurable).
A client that sees an irregularity (beacon not arriving within 2x the
regular interval) pings the IOC on the existing TCP connection.
If the IOC does not respond with 5 seconds, the connection (and all its
channels) are marked as disconnected, client callbacks being executed.
Don't know how could apply to your setup, though.
Cheers,
~Ralph
- Monitoring whether an IP device is connected or not David Michel
Re: Monitoring whether an IP device is connected or not Jack
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
