The option is -S, i.e. uppercase.
corvette:dxp/dxpApp/src>caget -help
Usage: caget [options] <PV name> ...
-h: Help: Print this message
Channel Access options:
-w <sec>: Wait time, specifies CA timeout, default is 1.000000 second(s)
-c: Asynchronous get (use ca_get_callback and wait for completion)
-p <prio>: CA priority (0-99, default 0=lowest)
Format options:
Default output format is "name value"
-t: Terse mode - print only value, without name
-a: Wide mode "name timestamp value stat sevr" (read PVs as DBR_TIME_xxx)
-d <type>: Request specific dbr type; use string (DBR_ prefix may be omitted)
or number of one of the following types:
DBR_STRING 0 DBR_STS_FLOAT 9 DBR_TIME_LONG 19 DBR_CTRL_SHORT 29
DBR_INT 1 DBR_STS_ENUM 10 DBR_TIME_DOUBLE 20 DBR_CTRL_INT 29
DBR_SHORT 1 DBR_STS_CHAR 11 DBR_GR_STRING 21 DBR_CTRL_FLOAT 30
DBR_FLOAT 2 DBR_STS_LONG 12 DBR_GR_SHORT 22 DBR_CTRL_ENUM 31
DBR_ENUM 3 DBR_STS_DOUBLE 13 DBR_GR_INT 22 DBR_CTRL_CHAR 32
DBR_CHAR 4 DBR_TIME_STRING 14 DBR_GR_FLOAT 23 DBR_CTRL_LONG 33
DBR_LONG 5 DBR_TIME_INT 15 DBR_GR_ENUM 24 DBR_CTRL_DOUBLE 34
DBR_DOUBLE 6 DBR_TIME_SHORT 15 DBR_GR_CHAR 25 DBR_STSACK_STRING 37
DBR_STS_STRING 7 DBR_TIME_FLOAT 16 DBR_GR_LONG 26 DBR_CLASS_NAME 38
DBR_STS_SHORT 8 DBR_TIME_ENUM 17 DBR_GR_DOUBLE 27
DBR_STS_INT 8 DBR_TIME_CHAR 18 DBR_CTRL_STRING 28
Enum format:
-n: Print DBF_ENUM value as number (default is enum string)
Arrays: Value format: print number of requested values, then list of values
Default: Print all values
-# <count>: Print first <count> elements of an array
-S: Print array of char as a string (long string)
Floating point type format:
Default: Use %g format
-e <nr>: Use %e format, with a precision of <nr> digits
-f <nr>: Use %f format, with a precision of <nr> digits
-g <nr>: Use %g format, with a precision of <nr> digits
-s: Get value as string (honors server-side precision)
-lx: Round to long integer and print as hex number
-lo: Round to long integer and print as octal number
-lb: Round to long integer and print as binary number
Integer number format:
Default: Print as decimal number
-0x: Print as hex number
-0o: Print as octal number
-0b: Print as binary number
Alternate output field separator:
-F <ofs>: Use <ofs> as an alternate output field separator
Example: caget -a -f8 my_channel another_channel
(uses wide output format, doubles are printed as %f with precision of 8)
But it does not seem to exist in your version, I don't know when it was added.
-----Original Message-----
From: Zelazny, Michael Stanley [mailto:[email protected]]
Sent: Tuesday, February 25, 2014 8:43 AM
To: Mark Rivers; Ganesh Jangir; [email protected]
Cc: controls-software
Subject: RE: Store long strings in EPICS record.
What version of caget do I need to get this behavior?
~/zelazny>caget -s SIOC:SYS0:ML00:CA001
SIOC:SYS0:ML00:CA001 1000 84 'T' 104 'h' 105 'i' 115 's' 32 ' ' 105 'i' 115 's' 32 ' ' 97 'a' 32 ' ' 118 'v' 101 'e' 114 'r' 121 'y' 32 ' ' 108 'l' 111 'o' 110 'n' 103 'g' 32 ' ' 115 's' 116 't' 114 'r' 105 'i' 110 'n' 103 'g' 46 '.' 32 ' ' 73 'I' 116 't' 39 ''' 115 's' 32 ' ' 49 '1' 48 '0' 48 '0' 48 '0' 32 ' ' 99 'c' 104 'h' 97 'a' 114 'r' 97 'a' 99 'c' 116 't' 101 'e' 114 'r' 115 's' 32 ' ' 108 'l' 111 'o' 110 'n' 103 'g' 46 '.' 32 ' ' 69 'E' 110 'n' 106 'j' 111 'o' 121 'y' 33 '!' 32 ' ' 102 'f' 114 'r' 111 'o' 109 'm' 32 ' ' 77 'M' 97 'a' 116 't' 108 'l' 97 'a' 98 'b' 32 ' ' 117 'u' 115 's' 101 'e' 32 ' ' 100 'd' 111 'o' 117 'u' 98 'b' 108 'l' 101 'e' 40 '(' 105 'i' 110 'n' 116 't' 56 '8' 40 '(' 39 ''' 89 'Y' 111 'o' 117 'u' 114 'r' 32 ' ' 83 'S' 84 'T' 82 'R' 39 ''' 41 ')' 32 ' ' 32 ' ' 116 't' 111 'o' 32 ' ' 108 'l' 99 'c' 97 'a' 80 'P' 117 'u' 116 't' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' !
32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 3!
2 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32!
' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 !
' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 '!
' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' !
' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' '!
~/zelazny>caget -h
-w <sec>: Wait time, specifies longer CA timeout, default is 1.000000 second
-c: Asynchronous get (use ca_get_callback instead of ca_get)
Format options:
Enum format:
-s: Get value as string (may honour server-side precision)
~/zelazny> ~/zelazny>cainfo SIOC:SYS0:ML00:CA001
State: connected
Host: <node-name-removed>.slac.stanford.edu:42312
Access: read, write
Data type: DBR_CHAR (native: DBF_CHAR)
Element count: 1000
~/zelazny>
From: [email protected] [[email protected]] On Behalf Of Mark Rivers [[email protected]]
Sent: Tuesday, February 25, 2014 3:49 AM
To: Ganesh Jangir; [email protected]
You cannot store a long string in a stringin record.
However, you can store a long string in a waveform record with FTVL=CHAR. caget, medm and other clients know how to display this correctly.
Here is an example:
corvette:~>cainfo GSE-PIL1:cam1:FullFileName_RBV
State: connected
Host: 164.54.160.161:5064
Access: read, write
Native data type: DBF_CHAR
Request type: DBR_CHAR
Element count: 256
corvette:~>caget -S GSE-PIL1:cam1:FullFileName_RBV
GSE-PIL1:cam1:FullFileName_RBV /cars5/Data/gpd_user/data/idc/2014/run1/eng/testing/images/testing_1/S045/stubbs_test_1002.tif
From: [email protected] [[email protected]] on behalf of Ganesh Jangir [[email protected]]
Sent: Tuesday, February 25, 2014 5:32 AM
To: [email protected]
Subject: Store long strings in EPICS record.
Dear All,
How to store array of strings, char arr[64][64] or a long string of size (65x64) byte in to EPICS record.
Its needed to communicate via Channel Access to Sequencer.What are the suitable ways to achieve this.
How to increase size of record type stringIn.
Thanks and Regards
Ganesh Jangir
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
- RE: Store long strings in EPICS record. Zelazny, Michael Stanley
- Store long strings in EPICS record. Ganesh Jangir
- RE: Store long strings in EPICS record. Mark Rivers
Re: Store long strings in EPICS record. Ralph Lange
Re: Trouble with caget with denSnmp John A. Priller
<2014>
2025
<2014>
2025
