To: Andrew Johnson <[email protected]> From: Anindya Roy/B/vecc Date: 02/26/2014 10:32AM Subject: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw (See attached file: build_log.txt) Dear Andrew Thanks for your reply, however base-3.15.0.1 is available for download at epics site at the following link and it was released on August 1, 2012. http://www.aps.anl.gov/epics/download/base/index.php One more thing, I have built base-3.15.0.1 for windows using cross compiler on linux platform (as suggested in Release note) and as far as example ioc is concerned, it is running on Windows XP (32 bit). Regarding Epics base-3.14.12.3, the build error looks similar, the build log is attached for you. Kindly help me out, actually we are using epics for quite a long time (base-3.14.8.2), now we feel to update our version. Thanks again Anindya अ निंद्य रॉय / Anindya Roy वैज्ञ��निक अधिकारी / Scientific Officer कंप्यूटर एवं सूचना वर��ग / Computer and Informatics Group परिवर्ती उर्जा साइक्लोट्रॉन केंद्र / Variable Energy Cyclotron Centre परमाणु उर्जा विभाग / Department of Atomic Energy भारत सरकार / Government of India 1/ए एफ विधान नगर / 1/AF Bidhan Nagar को��काता - 700064 , भा��त / Kolkata - 700064, India फोन / Ph (O): +91-033-23184558 फैक्स / Fax (O): +91-033-23346871 -----Andrew Johnson <[email protected]> wrote: ----- To: Anindya Roy <[email protected]>, <[email protected]> From: Andrew Johnson <[email protected]> Date: 02/25/2014 09:26PM Subject: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw Hi, On 02/25/2014 02:27 AM, Anindya Roy wrote: > The build log file for epics base-3.15.0.1 using mingw and GNU Make 3.81 > on Windows X 32 bit is attached. The 3.15.0.1 release was for EPICS developers only and is coming up for 2 years old, so it is very out of date compared to the development branch in our version control system. There will be a 3.15.1 release for application and operational use at some point in the future, but until then please use the 3.14.12 series for application development. - Andrew -- Advertising may be described as the science of arresting the human intelligence long enough to get money from it. -- Stephen Leacock make -C ./configure install make[1]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/configure' perl ../src/tools/makeMakefile.pl O.win32-x86-mingw ../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86-mingw -f ../Makefile TOP=../.. T_A=win32-x86-mingw install make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/configure/O.win32-x86-mingw' make[2]: Nothing to be done for `install'. make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/configure/O.win32-x86-mingw' make[1]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/configure' make -C ./src install make[1]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src' make -C ./tools install make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/tools' perl ../../src/tools/makeMakefile.pl O.win32-x86-mingw ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86-mingw -f ../Makefile TOP=../../.. T_A=win32-x86-mingw install make[3]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/tools/O.win32-x86-mingw' "Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm" mkdir ../../../lib mkdir ../../../lib/perl mkdir ../../../lib/perl/EPICS "Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm" "Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm" "Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm" "Installing script ../../../bin/win32-x86-mingw/convertRelease.pl" mkdir ../../../bin mkdir ../../../bin/win32-x86-mingw "Installing script ../../../bin/win32-x86-mingw/cvsclean.pl" "Installing script ../../../bin/win32-x86-mingw/dos2unix.pl" "Installing script ../../../bin/win32-x86-mingw/expandVars.pl" "Installing script ../../../bin/win32-x86-mingw/filterWarnings.pl" "Installing script ../../../bin/win32-x86-mingw/fullPathName.pl" "Installing script ../../../bin/win32-x86-mingw/installEpics.pl" "Installing script ../../../bin/win32-x86-mingw/makeIncludeDbd.pl" "Installing script ../../../bin/win32-x86-mingw/makeMakefile.pl" "Installing script ../../../bin/win32-x86-mingw/makeTestfile.pl" "Installing script ../../../bin/win32-x86-mingw/mkmf.pl" "Installing script ../../../bin/win32-x86-mingw/munch.pl" "Installing script ../../../bin/win32-x86-mingw/replaceVAR.pl" "Installing script ../../../bin/win32-x86-mingw/useManifestTool.pl" make[3]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/tools/O.win32-x86-mingw' make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/tools' make -C ./makeBaseApp install make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseApp' perl ../../bin/win32-x86-mingw/makeMakefile.pl O.win32-x86-mingw ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86-mingw -f ../Makefile TOP=../../.. T_A=win32-x86-mingw install make[3]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseApp/O.win32-x86-mingw' "Installing script ../../../bin/win32-x86-mingw/makeBaseApp.pl" "Installing ../../../templates/makeBaseApp/top/Makefile" mkdir ../../../templates mkdir ../../../templates/makeBaseApp mkdir ../../../templates/makeBaseApp/top "Installing ../../../templates/makeBaseApp/top/configure/CONFIG" mkdir ../../../templates/makeBaseApp/top/configure "Installing ../../../templates/makeBaseApp/top/configure/CONFIG_SITE" "Installing ../../../templates/makeBaseApp/top/configure/Makefile" "Installing ../../../templates/makeBaseApp/top/configure/RELEASE" "Installing ../../../templates/makeBaseApp/top/configure/RULES" "Installing ../../../templates/makeBaseApp/top/configure/RULES.ioc" "Installing ../../../templates/makeBaseApp/top/configure/RULES_DIRS" "Installing ../../../templates/makeBaseApp/top/configure/RULES_TOP" "Installing ../../../templates/makeBaseApp/top/supportApp/Makefile" mkdir ../../../templates/makeBaseApp/top/supportApp "Installing ../../../templates/makeBaseApp/top/supportApp/Db/Makefile" mkdir ../../../templates/makeBaseApp/top/supportApp/Db "Installing ../../../templates/makeBaseApp/top/supportApp/src/Makefile" mkdir ../../../templates/makeBaseApp/top/supportApp/src "Installing ../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd" "Installing ../../../templates/makeBaseApp/top/iocApp/Makefile" mkdir ../../../templates/makeBaseApp/top/iocApp "Installing ../../../templates/makeBaseApp/top/iocApp/Db/Makefile" mkdir ../../../templates/makeBaseApp/top/iocApp/Db "Installing ../../../templates/makeBaseApp/top/iocApp/src/Makefile" mkdir ../../../templates/makeBaseApp/top/iocApp/src "Installing ../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp" "Installing ../../../templates/makeBaseApp/top/exampleApp/Makefile" mkdir ../../../templates/makeBaseApp/top/exampleApp "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/Makefile" mkdir ../../../templates/makeBaseApp/top/exampleApp/Db "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db" "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db" "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db" "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions" "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/userHost.substitutions" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/Makefile" mkdir ../../../templates/makeBaseApp/top/exampleApp/src "Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd" "Installing ../../../templates/makeBaseApp/top/exampleBoot/Makefile" mkdir ../../../templates/makeBaseApp/top/exampleBoot "Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks" "Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common" mkdir ../../../templates/makeBaseApp/top/exampleBoot/ioc "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks" "Installing ../../../templates/makeBaseApp/top/caClientApp/Makefile" mkdir ../../../templates/makeBaseApp/top/caClientApp "Installing ../../../templates/makeBaseApp/top/caClientApp/caExample.c" "Installing ../../../templates/makeBaseApp/top/caClientApp/caMonitor.c" "Installing ../../../templates/makeBaseApp/top/caServerApp/Makefile" mkdir ../../../templates/makeBaseApp/top/caServerApp "Installing ../../../templates/makeBaseApp/top/caServerApp/README" "Installing ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exPV.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.h" "Installing ../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/main.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/test.adl" "Installing ../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc" "Installing ../../../templates/makeBaseApp/top/iocBoot/Makefile" mkdir ../../../templates/makeBaseApp/top/iocBoot "Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks" "Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common" mkdir ../../../templates/makeBaseApp/top/iocBoot/ioc "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS" make[3]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseApp/O.win32-x86-mingw' make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseApp' make -C ./makeBaseExt install make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseExt' perl ../../bin/win32-x86-mingw/makeMakefile.pl O.win32-x86-mingw ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86-mingw -f ../Makefile TOP=../../.. T_A=win32-x86-mingw install make[3]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseExt/O.win32-x86-mingw' "Installing script ../../../bin/win32-x86-mingw/makeBaseExt.pl" "Installing ../../../templates/makeBaseExt/top/Makefile" mkdir ../../../templates/makeBaseExt mkdir ../../../templates/makeBaseExt/top "Installing ../../../templates/makeBaseExt/top/README" "Installing ../../../templates/makeBaseExt/top/configure/CONFIG" mkdir ../../../templates/makeBaseExt/top/configure "Installing ../../../templates/makeBaseExt/top/configure/CONFIG_SITE" "Installing ../../../templates/makeBaseExt/top/configure/Makefile" "Installing ../../../templates/makeBaseExt/top/configure/RELEASE" "Installing ../../../templates/makeBaseExt/top/configure/RULES" "Installing ../../../templates/makeBaseExt/top/configure/RULES_DIRS" "Installing ../../../templates/makeBaseExt/top/configure/RULES_TOP" "Installing ../../../templates/makeBaseExt/top/configure/RULES_PYTHON" "Installing ../../../templates/makeBaseExt/top/configure/RULES_IDL" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386" mkdir ../../../templates/makeBaseExt/top/configure/os "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.interix-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64" "Installing ../../../templates/makeBaseExt/top/src/Makefile" mkdir ../../../templates/makeBaseExt/top/src "Installing ../../../templates/makeBaseExt/top/exampleExt/Makefile" mkdir ../../../templates/makeBaseExt/top/exampleExt "Installing ../../../templates/makeBaseExt/top/exampleExt/caExample.c" "Installing ../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM" "Installing ../../../templates/makeBaseExt/top/simpleExt/Makefile" mkdir ../../../templates/makeBaseExt/top/simpleExt make[3]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseExt/O.win32-x86-mingw' make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseExt' make -C ./libCom install make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/libCom' perl ../../bin/win32-x86-mingw/makeMakefile.pl O.win32-x86-mingw ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86-mingw -f ../Makefile TOP=../../.. T_A=win32-x86-mingw install make[3]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/libCom/O.win32-x86-mingw' perl ../../../src/libCom/misc/makeEpicsVersion.pl ../../../configure/CONFIG _BASE_VERSION ../O.Common Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION Found EPICS Version 3.14.12.3 "Installing generated generic include file ../../../include/epicsVersion.h" mkdir ../../../include "Installing generic include file ../../../include/bucketLib.h" "Installing generic include file ../../../include/epicsRingPointer.h" "Installing generic include file ../../../include/epicsRingBytes.h" "Installing generic include file ../../../include/postfix.h" "Installing generic include file ../../../include/cvtFast.h" "Installing generic include file ../../../include/epicsAlgorithm.h" "Installing generic include file ../../../include/epicsExcept.h" "Installing generic include file ../../../include/epicsMemory.h" "Installing generic include file ../../../include/resourceLib.h" "Installing generic include file ../../../include/tsDLList.h" "Installing generic include file ../../../include/tsSLList.h" "Installing generic include file ../../../include/tsMinMax.h" "Installing generic include file ../../../include/tsBTree.h" "Installing generic include file ../../../include/tsFreeList.h" "Installing generic include file ../../../include/epicsSingleton.h" "Installing generic include file ../../../include/epicsGuard.h" "Installing generic include file ../../../include/epicsOnce.h" "Installing generic include file ../../../include/dbmf.h" "Installing generic include file ../../../include/ellLib.h" "Installing generic include file ../../../include/envDefs.h" "Installing generic include file ../../../include/epicsPrint.h" "Installing generic include file ../../../include/errMdef.h" "Installing generic include file ../../../include/errSymTbl.h" "Installing generic include file ../../../include/errlog.h" "Installing generic include file ../../../include/error.h" "Installing generic include file ../../../include/fdManager.h" "Installing generic include file ../../../include/fdmgr.h" "Installing generic include file ../../../include/freeList.h" "Installing generic include file ../../../include/gpHash.h" "Installing generic include file ../../../include/iocsh.h" "Installing generic include file ../../../include/registry.h" "Installing generic include file ../../../include/libComRegister.h" "Installing generic include file ../../../include/iocLog.h" "Installing generic include file ../../../include/logClient.h" "Installing generic include file ../../../include/macLib.h" "Installing generic include file ../../../include/adjustment.h" "Installing generic include file ../../../include/cantProceed.h" "Installing generic include file ../../../include/dbDefs.h" "Installing generic include file ../../../include/epicsConvert.h" "Installing generic include file ../../../include/epicsExit.h" "Installing generic include file ../../../include/epicsStdlib.h" "Installing generic include file ../../../include/epicsString.h" "Installing generic include file ../../../include/epicsTypes.h" "Installing generic include file ../../../include/shareLib.h" "Installing generic include file ../../../include/epicsExport.h" "Installing generic include file ../../../include/unixFileName.h" "Installing generic include file ../../../include/locationException.h" "Installing generic include file ../../../include/ipAddrToAsciiAsynchronous.h" "Installing generic include file ../../../include/compilerDependencies.h" "Installing generic include file ../../../include/epicsUnitTest.h" "Installing generic include file ../../../include/testMain.h" "Installing generic include file ../../../include/os/WIN32/osiFileName.h" mkdir ../../../include/os mkdir ../../../include/os/WIN32 "Installing generic include file ../../../include/osiSock.h" "Installing generic include file ../../../include/os/WIN32/osdSock.h" "Installing generic include file ../../../include/epicsInterrupt.h" "Installing os dependent include file ../../../include/os/WIN32/osdInterrupt.h" "Installing generic include file ../../../include/epicsMutex.h" "Installing generic include file ../../../include/os/WIN32/osdMutex.h" "Installing generic include file ../../../include/epicsEvent.h" "Installing generic include file ../../../include/os/WIN32/osdEvent.h" "Installing generic include file ../../../include/os/WIN32/epicsMath.h" "Installing os dependent include file ../../../include/os/WIN32/osdMessageQueue.h" "Installing generic include file ../../../include/os/WIN32/osdStrtod.h" "Installing generic include file ../../../include/epicsAssert.h" "Installing generic include file ../../../include/epicsFindSymbol.h" "Installing generic include file ../../../include/osiPoolStatus.h" "Installing generic include file ../../../include/os/WIN32/osdPoolStatus.h" "Installing generic include file ../../../include/os/WIN32/osdThread.h" "Installing generic include file ../../../include/epicsThread.h" "Installing generic include file ../../../include/epicsTime.h" "Installing generic include file ../../../include/epicsGeneralTime.h" "Installing generic include file ../../../include/os/WIN32/osdTime.h" "Installing generic include file ../../../include/generalTimeSup.h" "Installing generic include file ../../../include/osiClockTime.h" "Installing generic include file ../../../include/epicsSignal.h" "Installing generic include file ../../../include/osiProcess.h" "Installing generic include file ../../../include/os/WIN32/osiUnistd.h" "Installing generic include file ../../../include/osiWireFormat.h" "Installing os dependent include file ../../../include/os/WIN32/osdWireFormat.h" "Installing generic include file ../../../include/os/WIN32/osdWireConfig.h" "Installing generic include file ../../../include/epicsEndian.h" "Installing os dependent include file ../../../include/os/WIN32/epicsReadline.h" "Installing generic include file ../../../include/epicsMessageQueue.h" "Installing generic include file ../../../include/epicsStdio.h" "Installing generic include file ../../../include/epicsStdioRedirect.h" "Installing generic include file ../../../include/os/WIN32/epicsGetopt.h" "Installing generic include file ../../../include/devLib.h" "Installing generic include file ../../../include/devLibVME.h" "Installing generic include file ../../../include/devLibVMEImpl.h" "Installing os dependent include file ../../../include/os/WIN32/osdVME.h" "Installing generic include file ../../../include/taskwd.h" "Installing generic include file ../../../include/epicsTimer.h" "Installing generic include file ../../../include/tsDefs.h" windres -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../Com.rc Com.coff "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/bucketLib/bucketLib.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/ring/epicsRingPointer.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/ring/epicsRingBytes.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/calc/postfix.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/calc/calcPerform.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/cvtFast/cvtFast.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/cxxTemplates/resourceLib.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/cxxTemplates/epicsOnce.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/dbmf/dbmf.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/ellLib/ellLib.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/env/envSubr.c perl ../../../src/libCom/env/bldEnvData.pl ../../../configure Generating envData.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include envData.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/error/errlog.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/error/errSymLib.c perl ../../../src/libCom/error/makeStatTbl.pl ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include errSymTbl.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/fdmgr/fdmgr.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/fdmgr/fdManager.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/freeList/freeListLib.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/gpHash/gpHashLib.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/iocsh/iocsh.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/iocsh/registry.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/iocsh/libComRegister.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/logClient/iocLog.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/logClient/logClient.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/macLib/macCore.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/macLib/macEnv.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/macLib/macUtil.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/aToIPAddr.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/adjustment.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/cantProceed.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/epicsConvert.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/epicsExit.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/epicsStdlib.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/epicsString.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/truncateFile.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/misc/epicsUnitTest.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/epicsThread.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/epicsMutex.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/epicsEvent.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/epicsTime.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/epicsMessageQueue.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/epicsMath.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/epicsGeneralTime.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/osiClockTime.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/osdSock.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/osiSock.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/systemCallIntMech.cpp "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/default/osdAssert.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/default/osdFindSymbol.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/default/osdInterrupt.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/osdPoolStatus.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/osdSignal.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/default/osdEnv.c "" gcc -c -D_MINGW -O3 -Wall -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/default/epicsReadline.c "" g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/epicsStdio.c "" gcc -c -D_MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/osdStdio.c "" gcc -c -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING -D _MINGW -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include ../../../src/libCom/osi/os/WIN32/osdThread.c ../../../src/libCom/osi/os/WIN32/osdThread.c:99:13: error: conflicting types for 'DllMain' BOOL WINAPI DllMain ( ^ In file included from f:\epics_base\mingw\include\windows.h:62:0, from ../../../src/libCom/osi/os/WIN32/osdThread.c:29: f:\epics_base\mingw\include\winbase.h:1051:13: note: previous declaration of 'Dl lMain' was here BOOL WINAPI DllMain(HINSTANCE, DWORD, LPVOID); ^ make[3]: *** [osdThread.o] Error 1 make[2]: *** [install.win32-x86-mingw] Error 2 make[1]: *** [libCom.install] Error 2 make: *** [src.install] Error 2 make[3]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/libCom/O.win32-x86-mingw' make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/libCom' make[1]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src'
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
