Hi All, Thanks for your replies. I am a beginner of EPICS,Can any one help in this.. Error Code: ================================= Installing loadable shared library ../../../lib/linux-x86/libCap5.so Installing loadable shared library ../../../lib/perl/5.10.1/i386-linux-thread-multi/libCap5.so make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cap5/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cap5/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cap5/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cap5' make[1]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src' [root@localhost base-3.14.12.4]# ==================================== My system is CentOS release 6.5 32bit, I had installed perl-ExtUtils-ParseXS,readline-devel,perl-Module-Build, i dont know if i still missing some component of perl , or any other component. How can I do for this error? make -C ./configure install make[1]: Entering directory `/home/zj/Downloads/base-3.14.12.4/configure' perl ../src/tools/makeMakefile.pl O.linux-x86 ../.. perl ../src/tools/makeMakefile.pl O.linux-686 ../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/configure/O.linux-x86' make[2]: Nothing to be done for `install'. make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/configure/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../.. T_A=linux-686 install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/configure/O.linux-686' make[2]: Nothing to be done for `install'. make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/configure/O.linux-686' make[1]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/configure' make -C ./src install make[1]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src' make -C ./tools install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/tools' perl ../../src/tools/makeMakefile.pl O.linux-x86 ../../.. perl ../../src/tools/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/tools/O.linux-x86' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/tools/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/tools/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/tools/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/tools' make -C ./makeBaseApp install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseApp' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseApp/O.linux-x86' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseApp/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseApp/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseApp/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseApp' make -C ./makeBaseExt install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseExt' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseExt/O.linux-x86' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseExt/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseExt/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseExt/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/makeBaseExt' make -C ./libCom install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/libCom' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/O.linux-x86' perl ../../../src/libCom/misc/makeEpicsVersion.pl ../../../configure/CONFIG_BASE_VERSION ../O.Common Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION Found EPICS Version 3.14.12.4 Installing generated generic include file ../../../include/epicsVersion.h /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/bucketLib/bucketLib.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ring/epicsRingPointer.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ring/epicsRingBytes.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/calc/postfix.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/calc/calcPerform.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/cvtFast/cvtFast.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/cxxTemplates/resourceLib.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/cxxTemplates/epicsOnce.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/dbmf/dbmf.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ellLib/ellLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/env/envSubr.c perl ../../../src/libCom/env/bldEnvData.pl ../../../configure Generating envData.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include envData.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/error/errlog.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/error/errSymLib.c perl ../../../src/libCom/error/makeStatTbl.pl ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include errSymTbl.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/fdmgr/fdmgr.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/fdmgr/fdManager.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/freeList/freeListLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/gpHash/gpHashLib.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/iocsh/iocsh.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/iocsh/registry.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/iocsh/libComRegister.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/logClient/iocLog.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/logClient/logClient.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/macLib/macCore.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/macLib/macEnv.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/macLib/macUtil.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/aToIPAddr.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/adjustment.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/cantProceed.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsConvert.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsExit.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsStdlib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsString.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/truncateFile.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsUnitTest.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsThread.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsMutex.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsEvent.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsTime.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsMessageQueue.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsMath.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsGeneralTime.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/osiClockTime.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdSock.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdSockAddrReuse.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/osiSock.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/systemCallIntMech.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdAssert.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/Linux/osdFindSymbol.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdInterrupt.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdPoolStatus.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdSignal.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdEnv.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/epicsReadline.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/epicsTempFile.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsStdio.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdStdio.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdThread.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdMutex.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdEvent.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdTime.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdProcess.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdNetIntf.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdMessageQueue.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/devLibVME.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/devLibVMEOSD.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/taskwd/taskwd.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/epicsTimer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timerQueue.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timerQueueActive.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timerQueueActiveMgr.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timerQueuePassive.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/tsDefs/tsDefs.c /usr/bin/ar -rc libCom.a bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o /usr/bin/ranlib libCom.a /usr/bin/g++ -o libCom.so.3.14 -shared -fPIC -Wl,-hlibCom.so.3.14 -m32 bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libCom.so.3.14 ln -s libCom.so.3.14 ../../../lib/linux-x86/libCom.so Installing library ../../../lib/linux-x86/libCom.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/bucketLib/bucketLib.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ring/epicsRingPointer.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ring/epicsRingBytes.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/calc/postfix.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/calc/calcPerform.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/cvtFast/cvtFast.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/cxxTemplates/resourceLib.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/cxxTemplates/epicsOnce.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/dbmf/dbmf.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ellLib/ellLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/env/envSubr.c perl ../../../src/libCom/env/bldEnvData.pl ../../../configure Generating envData.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include envData.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/error/errlog.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/error/errSymLib.c perl ../../../src/libCom/error/makeStatTbl.pl ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include errSymTbl.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/fdmgr/fdmgr.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/fdmgr/fdManager.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/freeList/freeListLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/gpHash/gpHashLib.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/iocsh/iocsh.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/iocsh/registry.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/iocsh/libComRegister.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/logClient/iocLog.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/logClient/logClient.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/macLib/macCore.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/macLib/macEnv.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/macLib/macUtil.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/aToIPAddr.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/adjustment.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/cantProceed.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsConvert.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsExit.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsStdlib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsString.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/truncateFile.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/misc/epicsUnitTest.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsThread.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsMutex.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsEvent.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsTime.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsMessageQueue.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsMath.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsGeneralTime.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/osiClockTime.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdSock.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdSockAddrReuse.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/osiSock.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/systemCallIntMech.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdAssert.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/Linux/osdFindSymbol.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdInterrupt.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdPoolStatus.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdSignal.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdEnv.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/epicsReadline.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/epicsTempFile.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/epicsStdio.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdStdio.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdThread.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdMutex.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdEvent.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdTime.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/posix/osdProcess.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdNetIntf.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/osdMessageQueue.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/devLibVME.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/osi/os/default/devLibVMEOSD.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/taskwd/taskwd.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/epicsTimer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timerQueue.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timerQueueActive.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timerQueueActiveMgr.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/timer/timerQueuePassive.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/tsDefs/tsDefs.c /usr/bin/ar -rc libCom.a bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o /usr/bin/ranlib libCom.a /usr/bin/g++ -o libCom.so.3.14 -shared -fPIC -m32 bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libCom.so.3.14 ln -s libCom.so.3.14 ../../../lib/linux-686/libCom.so Installing library ../../../lib/linux-686/libCom.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/libCom' make -C ./toolsComm install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm' make -C ./antelope install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/antelope' perl ../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../.. perl ../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/antelope/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../closure.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../error.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../lalr.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../lr0.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../main.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../mkpar.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../output.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../reader.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../skeleton.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../symtab.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../verbose.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../warshall.c /usr/bin/g++ -o antelope -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 closure.o error.o lalr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o -lCom Installing created file ../../../../bin/linux-x86/antelope make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/antelope/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../.. T_A=linux-686 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/antelope/O.linux-686' make[4]: Nothing to be done for `install'. make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/antelope/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/antelope' make -C ./flex install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/flex' perl ../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../.. perl ../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/flex/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../ccl.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../dfa.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../ecs.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../gen.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../misc.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../nfa.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../sym.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../tblcmp.c rm -f parse.c y.tab.c rm -f parse.h y.tab.h ../../../../bin/linux-x86/antelope -l -d ../parse.y mv y.tab.c parse.c mv y.tab.h parse.h /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DDEFAULT_SKELETON_FILE=include/flex.skel.static -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -w -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include parse.c /usr/bin/g++ -o e_flex -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o -lCom Installing created file ../../../../bin/linux-x86/e_flex make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/flex/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../.. T_A=linux-686 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/flex/O.linux-686' make[4]: Nothing to be done for `install'. make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/flex/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm/flex' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/toolsComm' make -C ./ca install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/ca' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/ca/O.linux-x86' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cac.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacChannel.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacChannelNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacContextNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacReadNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacWriteNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacStateNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../access.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../iocinf.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../convert.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../test_event.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../repeater.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../searchTimer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../disconnectGovernorTimer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../repeaterSubscribeTimer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../baseNMIU.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../nciu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../netiiu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../udpiiu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../tcpiiu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../noopiiu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../netReadNotifyIO.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../netWriteNotifyIO.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../netSubscription.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../tcpSendWatchdog.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../tcpRecvWatchdog.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../bhe.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../ca_client_context.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../oldChannelNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../oldSubscription.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../getCallback.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../getCopy.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../putCallback.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../syncgrp.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../CASG.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../syncGroupNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../syncGroupReadNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../syncGroupWriteNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../localHostName.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../comQueRecv.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../comQueSend.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../comBuf.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../hostNameCache.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../msgForMultiplyDefinedPV.cpp /usr/bin/ar -rc libca.a cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o /usr/bin/ranlib libca.a /usr/bin/g++ -o libca.so.3.14 -shared -fPIC -Wl,-hlibca.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libca.so.3.14 ln -s libca.so.3.14 ../../../lib/linux-x86/libca.so Installing library ../../../lib/linux-x86/libca.a /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caRepeater.cpp /usr/bin/g++ -o caRepeater -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 caRepeater.o -lca -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../catimeMain.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../catime.c /usr/bin/g++ -o catime -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 catimeMain.o catime.o -lca -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../acctstMain.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../acctst.c /usr/bin/g++ -o acctst -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 acctstMain.o acctst.o -lca -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caConnTestMain.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caConnTest.cpp /usr/bin/g++ -o caConnTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 caConnTestMain.o caConnTest.o -lca -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../casw.cpp /usr/bin/g++ -o casw -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 casw.o -lca -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caEventRateMain.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caEventRate.cpp /usr/bin/g++ -o caEventRate -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 caEventRateMain.o caEventRate.o -lca -lCom Installing created file ../../../bin/linux-x86/caRepeater Installing created file ../../../bin/linux-x86/catime Installing created file ../../../bin/linux-x86/acctst Installing created file ../../../bin/linux-x86/caConnTest Installing created file ../../../bin/linux-x86/casw Installing created file ../../../bin/linux-x86/caEventRate make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/ca/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/ca/O.linux-686' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cac.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacChannel.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacChannelNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacContextNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacReadNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacWriteNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cacStateNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../access.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../iocinf.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../convert.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../test_event.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../repeater.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../searchTimer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../disconnectGovernorTimer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../repeaterSubscribeTimer.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../baseNMIU.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../nciu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../netiiu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../udpiiu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../tcpiiu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../noopiiu.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../netReadNotifyIO.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../netWriteNotifyIO.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../netSubscription.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../tcpSendWatchdog.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../tcpRecvWatchdog.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../bhe.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../ca_client_context.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../oldChannelNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../oldSubscription.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../getCallback.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../getCopy.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../putCallback.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../syncgrp.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../CASG.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../syncGroupNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../syncGroupReadNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../syncGroupWriteNotify.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../localHostName.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../comQueRecv.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../comQueSend.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../comBuf.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../hostNameCache.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../msgForMultiplyDefinedPV.cpp /usr/bin/ar -rc libca.a cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o /usr/bin/ranlib libca.a /usr/bin/g++ -o libca.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libca.so.3.14 ln -s libca.so.3.14 ../../../lib/linux-686/libca.so Installing library ../../../lib/linux-686/libca.a /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caRepeater.cpp /usr/bin/g++ -o caRepeater -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 caRepeater.o -lca -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../catimeMain.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../catime.c /usr/bin/g++ -o catime -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 catimeMain.o catime.o -lca -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../acctstMain.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../acctst.c /usr/bin/g++ -o acctst -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 acctstMain.o acctst.o -lca -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caConnTestMain.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caConnTest.cpp /usr/bin/g++ -o caConnTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 caConnTestMain.o caConnTest.o -lca -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../casw.cpp /usr/bin/g++ -o casw -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 casw.o -lca -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caEventRateMain.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caEventRate.cpp /usr/bin/g++ -o caEventRate -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 caEventRateMain.o caEventRate.o -lca -lCom Installing created file ../../../bin/linux-686/caRepeater Installing created file ../../../bin/linux-686/catime Installing created file ../../../bin/linux-686/acctst Installing created file ../../../bin/linux-686/caConnTest Installing created file ../../../bin/linux-686/casw Installing created file ../../../bin/linux-686/caEventRate make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/ca/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/ca' make -C ./dbStatic install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dbStatic' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dbStatic/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbStaticNoRun.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbStaticLib.c ../../../bin/linux-x86/e_flex -S../../../include/flex.skel.static -8 -I ../dbLex.l mv lex.yy.c dbLex.c rm -f dbYacc.c y.tab.c ../../../bin/linux-x86/antelope ../dbYacc.y mv y.tab.c dbYacc.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include dbYacc.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbPvdLib.c /usr/bin/ar -rc libdbStaticHost.a dbStaticNoRun.o dbStaticLib.o dbYacc.o dbPvdLib.o /usr/bin/ranlib libdbStaticHost.a /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbStaticRun.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbStaticIocRegister.c /usr/bin/ar -rc libdbStaticIoc.a dbStaticRun.o dbStaticIocRegister.o dbStaticLib.o dbYacc.o dbPvdLib.o /usr/bin/ranlib libdbStaticIoc.a /usr/bin/g++ -o libdbStaticHost.so.3.14 -shared -fPIC -Wl,-hlibdbStaticHost.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 dbStaticNoRun.o dbStaticLib.o dbYacc.o dbPvdLib.o -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libdbStaticHost.so.3.14 ln -s libdbStaticHost.so.3.14 ../../../lib/linux-x86/libdbStaticHost.so /usr/bin/g++ -o libdbStaticIoc.so.3.14 -shared -fPIC -Wl,-hlibdbStaticIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 dbStaticRun.o dbStaticIocRegister.o dbStaticLib.o dbYacc.o dbPvdLib.o -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libdbStaticIoc.so.3.14 ln -s libdbStaticIoc.so.3.14 ../../../lib/linux-x86/libdbStaticIoc.so Installing library ../../../lib/linux-x86/libdbStaticHost.a Installing library ../../../lib/linux-x86/libdbStaticIoc.a /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbReadTest.c /usr/bin/g++ -o dbReadTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 dbReadTest.o -ldbStaticHost -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbExpand.c /usr/bin/g++ -o dbExpand -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 dbExpand.o -ldbStaticHost -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbToMenuH.c /usr/bin/g++ -o dbToMenuH -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 dbToMenuH.o -ldbStaticHost -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbToRecordtypeH.c /usr/bin/g++ -o dbToRecordtypeH -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 dbToRecordtypeH.o -ldbStaticHost -lCom Installing created file ../../../bin/linux-x86/dbReadTest Installing created file ../../../bin/linux-x86/dbExpand Installing created file ../../../bin/linux-x86/dbToMenuH Installing created file ../../../bin/linux-x86/dbToRecordtypeH make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dbStatic/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dbStatic/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbStaticRun.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbStaticIocRegister.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbStaticLib.c ../../../bin/linux-x86/e_flex -S../../../include/flex.skel.static -8 -I ../dbLex.l mv lex.yy.c dbLex.c rm -f dbYacc.c y.tab.c ../../../bin/linux-x86/antelope ../dbYacc.y mv y.tab.c dbYacc.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include dbYacc.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbPvdLib.c /usr/bin/ar -rc libdbStaticIoc.a dbStaticRun.o dbStaticIocRegister.o dbStaticLib.o dbYacc.o dbPvdLib.o /usr/bin/ranlib libdbStaticIoc.a /usr/bin/g++ -o libdbStaticIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 dbStaticRun.o dbStaticIocRegister.o dbStaticLib.o dbYacc.o dbPvdLib.o -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libdbStaticIoc.so.3.14 ln -s libdbStaticIoc.so.3.14 ../../../lib/linux-686/libdbStaticIoc.so Installing library ../../../lib/linux-686/libdbStaticIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dbStatic/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dbStatic' make -C ./registry install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/registry' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/registry/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryRecordType.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryDeviceSupport.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryDriverSupport.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryFunction.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryCommon.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryIocRegister.c /usr/bin/ar -rc libregistryIoc.a registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o registryCommon.o registryIocRegister.o /usr/bin/ranlib libregistryIoc.a /usr/bin/g++ -o libregistryIoc.so.3.14 -shared -fPIC -Wl,-hlibregistryIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o registryCommon.o registryIocRegister.o -ldbStaticIoc -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libregistryIoc.so.3.14 ln -s libregistryIoc.so.3.14 ../../../lib/linux-x86/libregistryIoc.so Installing library ../../../lib/linux-x86/libregistryIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/registry/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/registry/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryRecordType.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryDeviceSupport.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryDriverSupport.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryFunction.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryCommon.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../registryIocRegister.c /usr/bin/ar -rc libregistryIoc.a registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o registryCommon.o registryIocRegister.o /usr/bin/ranlib libregistryIoc.a /usr/bin/g++ -o libregistryIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o registryCommon.o registryIocRegister.o -ldbStaticIoc -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libregistryIoc.so.3.14 ln -s libregistryIoc.so.3.14 ../../../lib/linux-686/libregistryIoc.so Installing library ../../../lib/linux-686/libregistryIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/registry/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/registry' make -C ./bpt install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/bpt' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/bpt/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../makeBpt.c /usr/bin/g++ -o makeBpt -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 makeBpt.o -lCom Installing created file ../../../bin/linux-x86/makeBpt ../../../bin/linux-x86/makeBpt ../bptTypeJdegC.data bptTypeJdegC.dbd ../../../bin/linux-x86/makeBpt ../bptTypeJdegF.data bptTypeJdegF.dbd ../../../bin/linux-x86/makeBpt ../bptTypeKdegC.data bptTypeKdegC.dbd ../../../bin/linux-x86/makeBpt ../bptTypeKdegF.data bptTypeKdegF.dbd Installing created dbd file ../../../dbd/bptTypeJdegC.dbd Installing created dbd file ../../../dbd/bptTypeJdegF.dbd Installing created dbd file ../../../dbd/bptTypeKdegC.dbd Installing created dbd file ../../../dbd/bptTypeKdegF.dbd echo "../O.Common/menuConvert.h : ../Makefile" >> menuConvert.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuConvert.dbd menuConvert.h Installing generated generic include file ../../../include/menuConvert.h make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/bpt/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/bpt/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/bpt/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/bpt' make -C ./db install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/db' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/db/O.linux-x86' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/db/O.linux-x86' make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/db/O.linux-x86' echo "../O.Common/menuAlarmSevr.h : ../Makefile" >> menuAlarmSevr.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuAlarmSevr.dbd menuAlarmSevr.h echo "../O.Common/menuAlarmStat.h : ../Makefile" >> menuAlarmStat.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuAlarmStat.dbd menuAlarmStat.h echo "../O.Common/menuCompress.h : ../Makefile" >> menuCompress.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuCompress.dbd menuCompress.h echo "../O.Common/menuFtype.h : ../Makefile" >> menuFtype.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuFtype.dbd menuFtype.h echo "../O.Common/menuIvoa.h : ../Makefile" >> menuIvoa.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuIvoa.dbd menuIvoa.h echo "../O.Common/menuOmsl.h : ../Makefile" >> menuOmsl.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuOmsl.dbd menuOmsl.h echo "../O.Common/menuPini.h : ../Makefile" >> menuPini.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuPini.dbd menuPini.h echo "../O.Common/menuPriority.h : ../Makefile" >> menuPriority.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuPriority.dbd menuPriority.h echo "../O.Common/menuScan.h : ../Makefile" >> menuScan.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuScan.dbd menuScan.h echo "../O.Common/menuYesNo.h : ../Makefile" >> menuYesNo.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuYesNo.dbd menuYesNo.h echo "../O.Common/menuSimm.h : ../Makefile" >> menuSimm.h.d ../../../bin/linux-x86/dbToMenuH -I. -I.. -I../O.Common -I../../../dbd ../menuSimm.dbd menuSimm.h rm -f ../O.Common/dbCommon.h ../../../bin/linux-x86/dbToRecordtypeH -I .. ../dbCommonRecord.dbd ../O.Common/dbCommon.h Installing generated generic include file ../../../include/menuAlarmSevr.h Installing generated generic include file ../../../include/menuAlarmStat.h Installing generated generic include file ../../../include/menuCompress.h Installing generated generic include file ../../../include/menuFtype.h Installing generated generic include file ../../../include/menuIvoa.h Installing generated generic include file ../../../include/menuOmsl.h Installing generated generic include file ../../../include/menuPini.h Installing generated generic include file ../../../include/menuPriority.h Installing generated generic include file ../../../include/menuScan.h Installing generated generic include file ../../../include/menuYesNo.h Installing generated generic include file ../../../include/menuSimm.h Installing generated generic include file ../../../include/dbCommon.h /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbLock.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbAccess.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbBkpt.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbConvert.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbFastLinkConv.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbNotify.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbScan.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbEvent.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbTest.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../db_access.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../db_test.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../recGbl.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../callback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbCa.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbCaTest.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../initHooks.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cvtBpt.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbContext.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbChannelIO.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbSubscriptionIO.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbPutNotifyBlocker.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbContextReadNotifyCache.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../templateInstances.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbIocRegister.c /usr/bin/ar -rc libdbIoc.a dbLock.o dbAccess.o dbBkpt.o dbConvert.o dbFastLinkConv.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o dbIocRegister.o /usr/bin/ranlib libdbIoc.a /usr/bin/g++ -o libdbIoc.so.3.14 -shared -fPIC -Wl,-hlibdbIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 dbLock.o dbAccess.o dbBkpt.o dbConvert.o dbFastLinkConv.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o dbIocRegister.o -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libdbIoc.so.3.14 ln -s libdbIoc.so.3.14 ../../../lib/linux-x86/libdbIoc.so Installing library ../../../lib/linux-x86/libdbIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/db/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/db/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/db/O.linux-686' make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/db/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbLock.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbAccess.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbBkpt.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbConvert.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbFastLinkConv.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbNotify.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbScan.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbEvent.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbTest.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../db_access.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../db_test.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../recGbl.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../callback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbCa.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbCaTest.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../initHooks.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cvtBpt.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbContext.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbChannelIO.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbSubscriptionIO.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbPutNotifyBlocker.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbContextReadNotifyCache.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../templateInstances.cpp /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbIocRegister.c /usr/bin/ar -rc libdbIoc.a dbLock.o dbAccess.o dbBkpt.o dbConvert.o dbFastLinkConv.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o dbIocRegister.o /usr/bin/ranlib libdbIoc.a /usr/bin/g++ -o libdbIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 dbLock.o dbAccess.o dbBkpt.o dbConvert.o dbFastLinkConv.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o dbIocRegister.o -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libdbIoc.so.3.14 ln -s libdbIoc.so.3.14 ../../../lib/linux-686/libdbIoc.so Installing library ../../../lib/linux-686/libdbIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/db/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/db' make -C ./as install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/as' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/as/O.linux-x86' ../../../bin/linux-x86/e_flex -S../../../include/flex.skel.static -8 -I ../asLib_lex.l mv lex.yy.c asLib_lex.c rm -f asLib.c y.tab.c ../../../bin/linux-x86/antelope ../asLib.y mv y.tab.c asLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include asLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asTrapWrite.c /usr/bin/ar -rc libasHost.a asLib.o asTrapWrite.o /usr/bin/ranlib libasHost.a /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asDbLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asCa.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asIocRegister.c /usr/bin/ar -rc libasIoc.a asDbLib.o asCa.o asIocRegister.o asLib.o asTrapWrite.o /usr/bin/ranlib libasIoc.a /usr/bin/g++ -o libasHost.so.3.14 -shared -fPIC -Wl,-hlibasHost.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 asLib.o asTrapWrite.o -ldbStaticHost -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libasHost.so.3.14 ln -s libasHost.so.3.14 ../../../lib/linux-x86/libasHost.so /usr/bin/g++ -o libasIoc.so.3.14 -shared -fPIC -Wl,-hlibasIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 asDbLib.o asCa.o asIocRegister.o asLib.o asTrapWrite.o -ldbIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libasIoc.so.3.14 ln -s libasIoc.so.3.14 ../../../lib/linux-x86/libasIoc.so Installing library ../../../lib/linux-x86/libasHost.a Installing library ../../../lib/linux-x86/libasIoc.a /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../ascheck.c /usr/bin/g++ -o ascheck -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 ascheck.o -lasHost -ldbStaticHost -lca -lCom Installing created file ../../../bin/linux-x86/ascheck make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/as/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/as/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asDbLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asCa.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asIocRegister.c ../../../bin/linux-x86/e_flex -S../../../include/flex.skel.static -8 -I ../asLib_lex.l mv lex.yy.c asLib_lex.c rm -f asLib.c y.tab.c ../../../bin/linux-x86/antelope ../asLib.y mv y.tab.c asLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include asLib.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asTrapWrite.c /usr/bin/ar -rc libasIoc.a asDbLib.o asCa.o asIocRegister.o asLib.o asTrapWrite.o /usr/bin/ranlib libasIoc.a /usr/bin/g++ -o libasIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 asDbLib.o asCa.o asIocRegister.o asLib.o asTrapWrite.o -ldbIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libasIoc.so.3.14 ln -s libasIoc.so.3.14 ../../../lib/linux-686/libasIoc.so Installing library ../../../lib/linux-686/libasIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/as/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/as' make -C ./util install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/util' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/util/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../ca_test_main.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../ca_test.c /usr/bin/g++ -o ca_test -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 ca_test_main.o ca_test.o -lca -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../iocLogServer.c /usr/bin/g++ -o iocLogServer -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 iocLogServer.o -lca -lCom Installing created file ../../../bin/linux-x86/ca_test Installing created file ../../../bin/linux-x86/iocLogServer make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/util/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/util/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/util/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/util' make -C ./dbtools install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dbtools' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dbtools/O.linux-x86' ../../../bin/linux-x86/e_flex -S../../../include/flex.skel.static -8 -I ../dbLoadTemplate_lex.l mv lex.yy.c dbLoadTemplate_lex.c rm -f dbLoadTemplate.c y.tab.c ../../../bin/linux-x86/antelope ../dbLoadTemplate.y mv y.tab.c dbLoadTemplate.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include dbLoadTemplate.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbtoolsIocRegister.c /usr/bin/ar -rc libdbtoolsIoc.a dbLoadTemplate.o dbtoolsIocRegister.o /usr/bin/ranlib libdbtoolsIoc.a /usr/bin/g++ -o libdbtoolsIoc.so.3.14 -shared -fPIC -Wl,-hlibdbtoolsIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 dbLoadTemplate.o dbtoolsIocRegister.o -ldbIoc -ldbStaticIoc -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libdbtoolsIoc.so.3.14 ln -s libdbtoolsIoc.so.3.14 ../../../lib/linux-x86/libdbtoolsIoc.so Installing library ../../../lib/linux-x86/libdbtoolsIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dbtools/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dbtools/O.linux-686' ../../../bin/linux-x86/e_flex -S../../../include/flex.skel.static -8 -I ../dbLoadTemplate_lex.l mv lex.yy.c dbLoadTemplate_lex.c rm -f dbLoadTemplate.c y.tab.c ../../../bin/linux-x86/antelope ../dbLoadTemplate.y mv y.tab.c dbLoadTemplate.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include dbLoadTemplate.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbtoolsIocRegister.c /usr/bin/ar -rc libdbtoolsIoc.a dbLoadTemplate.o dbtoolsIocRegister.o /usr/bin/ranlib libdbtoolsIoc.a /usr/bin/g++ -o libdbtoolsIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 dbLoadTemplate.o dbtoolsIocRegister.o -ldbIoc -ldbStaticIoc -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libdbtoolsIoc.so.3.14 ln -s libdbtoolsIoc.so.3.14 ../../../lib/linux-686/libdbtoolsIoc.so Installing library ../../../lib/linux-686/libdbtoolsIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dbtools/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dbtools' make -C ./catools install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/catools' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../tool_lib.c /usr/bin/ar -rc libcatools.a tool_lib.o /usr/bin/ranlib libcatools.a /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caget.c /usr/bin/g++ -o caget -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -L/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86 -m32 caget.o -lcatools -lca -lCom -lpthread -lm -lrt -ldl -lgcc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../camonitor.c /usr/bin/g++ -o camonitor -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -L/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86 -m32 camonitor.o -lcatools -lca -lCom -lpthread -lm -lrt -ldl -lgcc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cainfo.c /usr/bin/g++ -o cainfo -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -L/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86 -m32 cainfo.o -lcatools -lca -lCom -lpthread -lm -lrt -ldl -lgcc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caput.c /usr/bin/g++ -o caput -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -L/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86 -m32 caput.o -lcatools -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing created file ../../../bin/linux-x86/caget Installing created file ../../../bin/linux-x86/camonitor Installing created file ../../../bin/linux-x86/cainfo Installing created file ../../../bin/linux-x86/caput make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../tool_lib.c /usr/bin/ar -rc libcatools.a tool_lib.o /usr/bin/ranlib libcatools.a /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caget.c /usr/bin/g++ -o caget -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -L/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686 -m32 caget.o -lcatools -lca -lCom -lpthread -lm -lrt -ldl -lgcc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../camonitor.c /usr/bin/g++ -o camonitor -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -L/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686 -m32 camonitor.o -lcatools -lca -lCom -lpthread -lm -lrt -ldl -lgcc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../cainfo.c /usr/bin/g++ -o cainfo -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -L/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686 -m32 cainfo.o -lcatools -lca -lCom -lpthread -lm -lrt -ldl -lgcc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../caput.c /usr/bin/g++ -o caput -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -L/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686 -m32 caput.o -lcatools -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing created file ../../../bin/linux-686/caget Installing created file ../../../bin/linux-686/camonitor Installing created file ../../../bin/linux-686/cainfo Installing created file ../../../bin/linux-686/caput make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/catools/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/catools' make -C ./rsrv install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/rsrv' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/rsrv/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../caserverio.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../caservertask.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../camsgtask.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../camessage.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../cast_server.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../online_notify.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../rsrvIocRegister.c /usr/bin/ar -rc librsrvIoc.a caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o /usr/bin/ranlib librsrvIoc.a /usr/bin/g++ -o librsrvIoc.so.3.14 -shared -fPIC -Wl,-hlibrsrvIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o -lasIoc -ldbIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/librsrvIoc.so.3.14 ln -s librsrvIoc.so.3.14 ../../../lib/linux-x86/librsrvIoc.so Installing library ../../../lib/linux-x86/librsrvIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/rsrv/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/rsrv/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../caserverio.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../caservertask.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../camsgtask.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../camessage.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../cast_server.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../online_notify.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../ca ../rsrvIocRegister.c /usr/bin/ar -rc librsrvIoc.a caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o /usr/bin/ranlib librsrvIoc.a /usr/bin/g++ -o librsrvIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o -lasIoc -ldbIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/librsrvIoc.so.3.14 ln -s librsrvIoc.so.3.14 ../../../lib/linux-686/librsrvIoc.so Installing library ../../../lib/linux-686/librsrvIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/rsrv/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/rsrv' make -C ./rec install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/rec' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/rec/O.linux-x86' echo "../O.Common/aaiRecord.h : ../Makefile" >> aaiRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../aaiRecord.dbd aaiRecord.h echo "../O.Common/aaoRecord.h : ../Makefile" >> aaoRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../aaoRecord.dbd aaoRecord.h echo "../O.Common/aiRecord.h : ../Makefile" >> aiRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../aiRecord.dbd aiRecord.h echo "../O.Common/aoRecord.h : ../Makefile" >> aoRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../aoRecord.dbd aoRecord.h echo "../O.Common/aSubRecord.h : ../Makefile" >> aSubRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../aSubRecord.dbd aSubRecord.h echo "../O.Common/biRecord.h : ../Makefile" >> biRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../biRecord.dbd biRecord.h echo "../O.Common/boRecord.h : ../Makefile" >> boRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../boRecord.dbd boRecord.h echo "../O.Common/calcRecord.h : ../Makefile" >> calcRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../calcRecord.dbd calcRecord.h echo "../O.Common/calcoutRecord.h : ../Makefile" >> calcoutRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../calcoutRecord.dbd calcoutRecord.h echo "../O.Common/compressRecord.h : ../Makefile" >> compressRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../compressRecord.dbd compressRecord.h echo "../O.Common/dfanoutRecord.h : ../Makefile" >> dfanoutRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../dfanoutRecord.dbd dfanoutRecord.h echo "../O.Common/eventRecord.h : ../Makefile" >> eventRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../eventRecord.dbd eventRecord.h echo "../O.Common/fanoutRecord.h : ../Makefile" >> fanoutRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../fanoutRecord.dbd fanoutRecord.h echo "../O.Common/histogramRecord.h : ../Makefile" >> histogramRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../histogramRecord.dbd histogramRecord.h echo "../O.Common/longinRecord.h : ../Makefile" >> longinRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../longinRecord.dbd longinRecord.h echo "../O.Common/longoutRecord.h : ../Makefile" >> longoutRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../longoutRecord.dbd longoutRecord.h echo "../O.Common/mbbiRecord.h : ../Makefile" >> mbbiRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../mbbiRecord.dbd mbbiRecord.h echo "../O.Common/mbbiDirectRecord.h : ../Makefile" >> mbbiDirectRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../mbbiDirectRecord.dbd mbbiDirectRecord.h echo "../O.Common/mbboRecord.h : ../Makefile" >> mbboRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../mbboRecord.dbd mbboRecord.h echo "../O.Common/mbboDirectRecord.h : ../Makefile" >> mbboDirectRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../mbboDirectRecord.dbd mbboDirectRecord.h echo "../O.Common/permissiveRecord.h : ../Makefile" >> permissiveRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../permissiveRecord.dbd permissiveRecord.h echo "../O.Common/selRecord.h : ../Makefile" >> selRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../selRecord.dbd selRecord.h echo "../O.Common/seqRecord.h : ../Makefile" >> seqRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../seqRecord.dbd seqRecord.h echo "../O.Common/stateRecord.h : ../Makefile" >> stateRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../stateRecord.dbd stateRecord.h echo "../O.Common/stringinRecord.h : ../Makefile" >> stringinRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../stringinRecord.dbd stringinRecord.h echo "../O.Common/stringoutRecord.h : ../Makefile" >> stringoutRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../stringoutRecord.dbd stringoutRecord.h echo "../O.Common/subRecord.h : ../Makefile" >> subRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../subRecord.dbd subRecord.h echo "../O.Common/subArrayRecord.h : ../Makefile" >> subArrayRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../subArrayRecord.dbd subArrayRecord.h echo "../O.Common/waveformRecord.h : ../Makefile" >> waveformRecord.h.d ../../../bin/linux-x86/dbToRecordtypeH -I. -I.. -I../O.Common -I../../../dbd ../waveformRecord.dbd waveformRecord.h Installing generated generic include file ../../../include/aaiRecord.h Installing generated generic include file ../../../include/aaoRecord.h Installing generated generic include file ../../../include/aiRecord.h Installing generated generic include file ../../../include/aoRecord.h Installing generated generic include file ../../../include/aSubRecord.h Installing generated generic include file ../../../include/biRecord.h Installing generated generic include file ../../../include/boRecord.h Installing generated generic include file ../../../include/calcRecord.h Installing generated generic include file ../../../include/calcoutRecord.h Installing generated generic include file ../../../include/compressRecord.h Installing generated generic include file ../../../include/dfanoutRecord.h Installing generated generic include file ../../../include/eventRecord.h Installing generated generic include file ../../../include/fanoutRecord.h Installing generated generic include file ../../../include/histogramRecord.h Installing generated generic include file ../../../include/longinRecord.h Installing generated generic include file ../../../include/longoutRecord.h Installing generated generic include file ../../../include/mbbiRecord.h Installing generated generic include file ../../../include/mbbiDirectRecord.h Installing generated generic include file ../../../include/mbboRecord.h Installing generated generic include file ../../../include/mbboDirectRecord.h Installing generated generic include file ../../../include/permissiveRecord.h Installing generated generic include file ../../../include/selRecord.h Installing generated generic include file ../../../include/seqRecord.h Installing generated generic include file ../../../include/stateRecord.h Installing generated generic include file ../../../include/stringinRecord.h Installing generated generic include file ../../../include/stringoutRecord.h Installing generated generic include file ../../../include/subRecord.h Installing generated generic include file ../../../include/subArrayRecord.h Installing generated generic include file ../../../include/waveformRecord.h /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aaiRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aaoRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aiRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aoRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aSubRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../biRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../boRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../calcRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../calcoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../compressRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dfanoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../eventRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../fanoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../histogramRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../longinRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../longoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../mbbiRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../mbbiDirectRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../mbboRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../mbboDirectRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../permissiveRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../selRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../seqRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../stateRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../stringinRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../stringoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../subRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../subArrayRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../waveformRecord.c /usr/bin/ar -rc librecIoc.a aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o longinRecord.o longoutRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o /usr/bin/ranlib librecIoc.a /usr/bin/g++ -o librecIoc.so.3.14 -shared -fPIC -Wl,-hlibrecIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o longinRecord.o longoutRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/librecIoc.so.3.14 ln -s librecIoc.so.3.14 ../../../lib/linux-x86/librecIoc.so Installing library ../../../lib/linux-x86/librecIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/rec/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/rec/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aaiRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aaoRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aiRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aoRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aSubRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../biRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../boRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../calcRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../calcoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../compressRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dfanoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../eventRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../fanoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../histogramRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../longinRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../longoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../mbbiRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../mbbiDirectRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../mbboRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../mbboDirectRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../permissiveRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../selRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../seqRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../stateRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../stringinRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../stringoutRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../subRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../subArrayRecord.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../waveformRecord.c /usr/bin/ar -rc librecIoc.a aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o longinRecord.o longoutRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o /usr/bin/ranlib librecIoc.a /usr/bin/g++ -o librecIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o longinRecord.o longoutRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/librecIoc.so.3.14 ln -s librecIoc.so.3.14 ../../../lib/linux-686/librecIoc.so Installing library ../../../lib/linux-686/librecIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/rec/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/rec' make -C ./misc install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/misc' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/misc/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../epicsRelease.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../iocInit.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asSubRecordFunctions.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../miscIocRegister.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dlload.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../iocshRegisterCommon.c /usr/bin/ar -rc libmiscIoc.a epicsRelease.o iocInit.o asSubRecordFunctions.o miscIocRegister.o dlload.o iocshRegisterCommon.o /usr/bin/ranlib libmiscIoc.a /usr/bin/g++ -o libmiscIoc.so.3.14 -shared -fPIC -Wl,-hlibmiscIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsRelease.o iocInit.o asSubRecordFunctions.o miscIocRegister.o dlload.o iocshRegisterCommon.o -lrsrvIoc -lasIoc -ldbtoolsIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libmiscIoc.so.3.14 ln -s libmiscIoc.so.3.14 ../../../lib/linux-x86/libmiscIoc.so Installing library ../../../lib/linux-x86/libmiscIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/misc/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/misc/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../epicsRelease.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../iocInit.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../asSubRecordFunctions.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../miscIocRegister.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dlload.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../iocshRegisterCommon.c /usr/bin/ar -rc libmiscIoc.a epicsRelease.o iocInit.o asSubRecordFunctions.o miscIocRegister.o dlload.o iocshRegisterCommon.o /usr/bin/ranlib libmiscIoc.a /usr/bin/g++ -o libmiscIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 epicsRelease.o iocInit.o asSubRecordFunctions.o miscIocRegister.o dlload.o iocshRegisterCommon.o -lrsrvIoc -lasIoc -ldbtoolsIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libmiscIoc.so.3.14 ln -s libmiscIoc.so.3.14 ../../../lib/linux-686/libmiscIoc.so Installing library ../../../lib/linux-686/libmiscIoc.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/misc/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/misc' make -C ./dev install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dev' make -C ./softDev install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dev/softDev' perl ../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../.. perl ../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dev/softDev/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAaiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAaoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAiSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAoSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBiSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBoSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devCalcoutSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devEventSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devHistogramSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devLiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devLoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbbiDirectSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbbiDirectSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbbiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbbiSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboDirectSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboDirectSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSASoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devWfSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devGeneralTime.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAoSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBoSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devCalcoutSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devLoSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboDirectSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSoSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devTimestamp.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSoStdio.c /usr/bin/ar -rc libsoftDevIoc.a devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBoSoft.o devBoSoftRaw.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devLiSoft.o devLoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devGeneralTime.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devLoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devSoSoftCallback.o devTimestamp.o devSoStdio.o /usr/bin/ranlib libsoftDevIoc.a /usr/bin/g++ -o libsoftDevIoc.so.3.14 -shared -fPIC -Wl,-hlibsoftDevIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBoSoft.o devBoSoftRaw.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devLiSoft.o devLoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devGeneralTime.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devLoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devSoSoftCallback.o devTimestamp.o devSoStdio.o -lmiscIoc -lrecIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../../lib/linux-x86/libsoftDevIoc.so.3.14 ln -s libsoftDevIoc.so.3.14 ../../../../lib/linux-x86/libsoftDevIoc.so Installing library ../../../../lib/linux-x86/libsoftDevIoc.a make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dev/softDev/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../.. T_A=linux-686 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dev/softDev/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAaiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAaoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAiSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAoSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBiSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBoSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devCalcoutSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devEventSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devHistogramSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devLiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devLoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbbiDirectSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbbiDirectSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbbiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbbiSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboDirectSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboDirectSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboSoftRaw.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSASoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSiSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSoSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devWfSoft.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devGeneralTime.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devAoSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devBoSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devCalcoutSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devLoSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devMbboDirectSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSoSoftCallback.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devTimestamp.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devSoStdio.c /usr/bin/ar -rc libsoftDevIoc.a devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBoSoft.o devBoSoftRaw.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devLiSoft.o devLoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devGeneralTime.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devLoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devSoSoftCallback.o devTimestamp.o devSoStdio.o /usr/bin/ranlib libsoftDevIoc.a /usr/bin/g++ -o libsoftDevIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBoSoft.o devBoSoftRaw.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devLiSoft.o devLoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devGeneralTime.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devLoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devSoSoftCallback.o devTimestamp.o devSoStdio.o -lmiscIoc -lrecIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../../lib/linux-686/libsoftDevIoc.so.3.14 ln -s libsoftDevIoc.so.3.14 ../../../../lib/linux-686/libsoftDevIoc.so Installing library ../../../../lib/linux-686/libsoftDevIoc.a make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dev/softDev/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dev/softDev' make -C ./testDev install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dev/testDev' perl ../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../.. perl ../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dev/testDev/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devHistogramTestAsyn.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devTestAsyn.c /usr/bin/ar -rc libtestDevIoc.a devHistogramTestAsyn.o devTestAsyn.o /usr/bin/ranlib libtestDevIoc.a /usr/bin/g++ -o libtestDevIoc.so.3.14 -shared -fPIC -Wl,-hlibtestDevIoc.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 devHistogramTestAsyn.o devTestAsyn.o -lmiscIoc -lrecIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../../lib/linux-x86/libtestDevIoc.so.3.14 ln -s libtestDevIoc.so.3.14 ../../../../lib/linux-x86/libtestDevIoc.so Installing library ../../../../lib/linux-x86/libtestDevIoc.a make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dev/testDev/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../.. T_A=linux-686 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/dev/testDev/O.linux-686' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devHistogramTestAsyn.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../devTestAsyn.c /usr/bin/ar -rc libtestDevIoc.a devHistogramTestAsyn.o devTestAsyn.o /usr/bin/ranlib libtestDevIoc.a /usr/bin/g++ -o libtestDevIoc.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 devHistogramTestAsyn.o devTestAsyn.o -lmiscIoc -lrecIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../../lib/linux-686/libtestDevIoc.so.3.14 ln -s libtestDevIoc.so.3.14 ../../../../lib/linux-686/libtestDevIoc.so Installing library ../../../../lib/linux-686/libtestDevIoc.a make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dev/testDev/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dev/testDev' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/dev' make -C ./vxWorks install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/vxWorks' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/vxWorks/O.linux-x86' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/vxWorks/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/vxWorks/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/vxWorks/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/vxWorks' make -C ./RTEMS install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/RTEMS' make -C ./base install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/RTEMS/base' perl ../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../.. perl ../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/RTEMS/base/O.linux-x86' make[4]: Nothing to be done for `install'. make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/RTEMS/base/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../.. T_A=linux-686 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/RTEMS/base/O.linux-686' make[4]: Nothing to be done for `install'. make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/RTEMS/base/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/RTEMS/base' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/RTEMS' make -C libCom/test install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/test' perl ../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../.. perl ../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/test/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsUnitTestTest.c /usr/bin/g++ -o epicsUnitTestTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsUnitTestTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsCalcTest.cpp /usr/bin/g++ -o epicsCalcTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsCalcTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsAlgorithmTest.cpp /usr/bin/g++ -o epicsAlgorithmTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsAlgorithmTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsMathTest.c /usr/bin/g++ -o epicsMathTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsMathTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsEllTest.c /usr/bin/g++ -o epicsEllTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsEllTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsEnvTest.c /usr/bin/g++ -o epicsEnvTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsEnvTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsErrlogTest.c /usr/bin/g++ -o epicsErrlogTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsErrlogTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsStdioTest.c /usr/bin/g++ -o epicsStdioTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsStdioTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsSockResolveTest.c /usr/bin/g++ -o epicsSockResolveTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsSockResolveTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsStringTest.c /usr/bin/g++ -o epicsStringTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsStringTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsTimeTest.cpp /usr/bin/g++ -o epicsTimeTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsTimeTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsThreadTest.cpp /usr/bin/g++ -o epicsThreadTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsThreadTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsThreadOnceTest.c /usr/bin/g++ -o epicsThreadOnceTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsThreadOnceTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsThreadPriorityTest.cpp /usr/bin/g++ -o epicsThreadPriorityTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsThreadPriorityTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsThreadPrivateTest.cpp /usr/bin/g++ -o epicsThreadPrivateTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsThreadPrivateTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsExitTest.c /usr/bin/g++ -o epicsExitTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsExitTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsTimerTest.cpp /usr/bin/g++ -o epicsTimerTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsTimerTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../ringPointerTest.c /usr/bin/g++ -o ringPointerTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 ringPointerTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../ringBytesTest.c /usr/bin/g++ -o ringBytesTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 ringBytesTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsEventTest.cpp /usr/bin/g++ -o epicsEventTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsEventTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsMutexTest.cpp /usr/bin/g++ -o epicsMutexTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsMutexTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsExceptionTest.cpp /usr/bin/g++ -o epicsExceptionTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsExceptionTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../macEnvExpandTest.c /usr/bin/g++ -o macEnvExpandTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 macEnvExpandTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../macLibTest.c /usr/bin/g++ -o macLibTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 macLibTest.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../taskwdTest.c /usr/bin/g++ -o taskwdTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 taskwdTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../blockingSockTest.cpp /usr/bin/g++ -o blockingSockTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 blockingSockTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsMessageQueueTest.cpp /usr/bin/g++ -o epicsMessageQueueTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsMessageQueueTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsThreadPerform.cpp /usr/bin/g++ -o epicsThreadPerform -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsThreadPerform.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../epicsMaxThreads.c /usr/bin/g++ -o epicsMaxThreads -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 epicsMaxThreads.o -lCom /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../buckTest.c /usr/bin/g++ -o buckTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 buckTest.o -lCom /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../cvtFastPerform.cpp /usr/bin/g++ -o cvtFastPerform -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 cvtFastPerform.o -lCom make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/test/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/test/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/test/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/libCom/test' make -C db/test install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/db/test' perl ../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../.. perl ../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/db/test/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include ../callbackTest.c /usr/bin/g++ -o callbackTest -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 callbackTest.o -ldbIoc -ldbStaticHost -lca -lCom make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/db/test/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/db/test/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/db/test/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/db/test' make -C ./softIoc install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/softIoc' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/softIoc/O.linux-x86' perl ../../../bin/linux-x86/makeIncludeDbd.pl base.dbd dlload.dbd system.dbd softIocInclude.dbd echo "../O.Common/softIocInclude.dbd : ../Makefile" >> softIoc.dbd.d Expanding dbd Installing created dbd file ../../../dbd/softIoc.dbd perl ../../../bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver /home/zj/Downloads/base-3.14.12.4 > softIoc.tmp mv softIoc.tmp softIoc_registerRecordDeviceDriver.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include softIoc_registerRecordDeviceDriver.cpp FINAL_LOCATION=/home/zj/Downloads/base-3.14.12.4 perl ../makeInstallDir.pl '/home/zj/Downloads/base-3.14.12.4' > epicsInstallDir.h /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../softMain.cpp /usr/bin/g++ -o softIoc -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 softIoc_registerRecordDeviceDriver.o softMain.o -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom Installing created file ../../../bin/linux-x86/softIoc make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/softIoc/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/softIoc/O.linux-686' perl ../../../bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver /home/zj/Downloads/base-3.14.12.4 > softIoc.tmp mv softIoc.tmp softIoc_registerRecordDeviceDriver.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include softIoc_registerRecordDeviceDriver.cpp FINAL_LOCATION=/home/zj/Downloads/base-3.14.12.4 perl ../makeInstallDir.pl '/home/zj/Downloads/base-3.14.12.4' > epicsInstallDir.h /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../softMain.cpp /usr/bin/g++ -o softIoc -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 softIoc_registerRecordDeviceDriver.o softMain.o -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom Installing created file ../../../bin/linux-686/softIoc make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/softIoc/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/softIoc' make -C ./gdd install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/gdd' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/gdd/O.linux-x86' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../genApps.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gdd.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddTest.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddAppTable.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddNewDel.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddAppDefs.cc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aitTypes.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aitGen.c /usr/bin/g++ -o aitGen -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 aitTypes.o aitGen.o -lCom Installing created file ../../../bin/linux-x86/aitGen ../../../bin/linux-x86/aitGen ../O.Common/aitConvertGenerated.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aitConvert.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aitHelpers.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddArray.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddContainer.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddErrorCodes.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddUtils.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddEnumStringTable.cc /usr/bin/g++ -o genApps -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 genApps.o gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o -lCom Installing created file ../../../bin/linux-x86/genApps ../../../bin/linux-x86/genApps ../O.Common/gddApps.h Installing generated generic include file ../../../include/gddApps.h /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -fno-strict-aliasing -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbMapper.cc /usr/bin/ar -rc libgdd.a gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o dbMapper.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o /usr/bin/ranlib libgdd.a /usr/bin/g++ -o libgdd.so.3.14 -shared -fPIC -Wl,-hlibgdd.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o dbMapper.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86/libgdd.so.3.14 ln -s libgdd.so.3.14 ../../../lib/linux-x86/libgdd.so Installing library ../../../lib/linux-x86/libgdd.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/gdd/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/gdd/O.linux-686' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gdd.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddTest.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddAppTable.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddNewDel.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddAppDefs.cc /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aitTypes.c /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aitConvert.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../aitHelpers.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../dbMapper.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddArray.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddContainer.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddErrorCodes.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddUtils.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -fno-strict-aliasing -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include ../gddEnumStringTable.cc /usr/bin/ar -rc libgdd.a gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o dbMapper.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o /usr/bin/ranlib libgdd.a /usr/bin/g++ -o libgdd.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o dbMapper.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-686/libgdd.so.3.14 ln -s libgdd.so.3.14 ../../../lib/linux-686/libgdd.so Installing library ../../../lib/linux-686/libgdd.a make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/gdd/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/gdd' make -C ./cas install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cas' make -C ./build install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cas/build' perl ../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../.. perl ../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cas/build/O.linux-x86' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/caServer.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/caServerI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casCoreClient.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casDGClient.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casStrmClient.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casPV.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casPVI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casChannel.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casChannelI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncIOI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncReadIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncReadIOI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncWriteIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncWriteIOI.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncPVExistIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncPVExistIOI.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncPVAttachIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncPVAttachIOI.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casEventSys.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casMonitor.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casMonEvent.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/inBuf.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/outBuf.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casCtx.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casEventMask.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/st/ioBlocked.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casBufferFactory.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/pvExistReturn.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/pvAttachReturn.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/caNetAddr.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/beaconTimer.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/beaconAnomalyGovernor.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/clientBufMemoryManager.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/chanIntfForPV.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/channelDestroyEvent.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/st/casIntfOS.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/st/casDGIntfOS.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/st/casStreamOS.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/caServerIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/casIntfIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/casDGIntfIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/casStreamIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/ipIgnoreEntry.cpp /usr/bin/ar -rc libcas.a caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o /usr/bin/ranlib libcas.a /usr/bin/g++ -o libcas.so.3.14 -shared -fPIC -Wl,-hlibcas.so.3.14 -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o -lca -lgdd -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../../lib/linux-x86/libcas.so.3.14 ln -s libcas.so.3.14 ../../../../lib/linux-x86/libcas.so Installing library ../../../../lib/linux-x86/libcas.a make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cas/build/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../.. T_A=linux-686 install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cas/build/O.linux-686' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/caServer.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/caServerI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casCoreClient.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casDGClient.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casStrmClient.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casPV.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casPVI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casChannel.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casChannelI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncIOI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncReadIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncReadIOI.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncWriteIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncWriteIOI.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncPVExistIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncPVExistIOI.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncPVAttachIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casAsyncPVAttachIOI.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casEventSys.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casMonitor.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casMonEvent.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/inBuf.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/outBuf.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casCtx.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casEventMask.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/st/ioBlocked.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/casBufferFactory.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/pvExistReturn.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/pvAttachReturn.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/caNetAddr.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/beaconTimer.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/beaconAnomalyGovernor.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/clientBufMemoryManager.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/chanIntfForPV.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/channelDestroyEvent.cpp /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/st/casIntfOS.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/st/casDGIntfOS.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/generic/st/casStreamOS.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/caServerIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/casIntfIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/casDGIntfIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/casStreamIO.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -march=i686 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include ../../../../src/cas/io/bsdSocket/ipIgnoreEntry.cpp /usr/bin/ar -rc libcas.a caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o /usr/bin/ranlib libcas.a /usr/bin/g++ -o libcas.so.3.14 -shared -fPIC -L/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-686 -m32 caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o -lca -lgdd -lCom -lpthread -lm -lrt -ldl -lgcc Installing shared library ../../../../lib/linux-686/libcas.so.3.14 ln -s libcas.so.3.14 ../../../../lib/linux-686/libcas.so Installing library ../../../../lib/linux-686/libcas.a make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cas/build/O.linux-686' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cas/build' make -C ./example install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cas/example' make -C ./directoryService install make[4]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cas/example/directoryService' perl ../../../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../../../.. perl ../../../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../../../.. T_A=linux-x86 install make[5]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cas/example/directoryService/O.linux-x86' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../../include/os/Linux -I../../../../../include ../main.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../../../include/os/Linux -I../../../../../include ../directoryServer.cc /usr/bin/g++ -o caDirServ -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 main.o directoryServer.o -lcas -lca -lgdd -lCom Installing created file ../../../../../bin/linux-x86/caDirServ make[5]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cas/example/directoryService/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../../../.. T_A=linux-686 install make[5]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cas/example/directoryService/O.linux-686' make[5]: Nothing to be done for `install'. make[5]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cas/example/directoryService/O.linux-686' make[4]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cas/example/directoryService' make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cas/example' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cas' make -C ./excas install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/excas' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/excas/O.linux-x86' /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../src/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include ../../../src/makeBaseApp/top/caServerApp/main.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../src/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include ../../../src/makeBaseApp/top/caServerApp/exServer.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../src/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include ../../../src/makeBaseApp/top/caServerApp/exPV.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../src/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include ../../../src/makeBaseApp/top/caServerApp/exVectorPV.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../src/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include ../../../src/makeBaseApp/top/caServerApp/exScalarPV.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../src/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include ../../../src/makeBaseApp/top/caServerApp/exAsyncPV.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -MMD -I. -I../O.Common -I. -I.. -I../../../src/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include ../../../src/makeBaseApp/top/caServerApp/exChannel.cc /usr/bin/g++ -o excas -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 main.o exServer.o exPV.o exVectorPV.o exScalarPV.o exAsyncPV.o exChannel.o -lcas -lgdd -lasHost -ldbStaticHost -lregistryIoc -lca -lCom Installing created file ../../../bin/linux-x86/excas make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/excas/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/excas/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/excas/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/excas' make -C ./cap5 install make[2]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cap5' perl ../../bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. perl ../../bin/linux-x86/makeMakefile.pl O.linux-686 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cap5/O.linux-x86' rm -f Cap5.c Cap5.c_new perl /usr/share/perl5/ExtUtils/xsubpp -typemap /usr/share/perl5/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -m32 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/lib/perl5/CORE Cap5.c /usr/bin/g++ -o libCap5.so -shared -fPIC -Wl,-hlibCap5.so -L/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -Wl,-rpath,/home/zj/Downloads/base-3.14.12.4/lib/linux-x86 -m32 Cap5.o -lca -lCom -lpthread -lm -lrt -ldl -lgcc Installing loadable shared library ../../../lib/linux-x86/libCap5.so Installing loadable shared library ../../../lib/perl/5.10.1/i386-linux-thread-multi/libCap5.so make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cap5/O.linux-x86' make -C O.linux-686 -f ../Makefile TOP=../../.. T_A=linux-686 install make[3]: Entering directory `/home/zj/Downloads/base-3.14.12.4/src/cap5/O.linux-686' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cap5/O.linux-686' make[2]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src/cap5' make[1]: Leaving directory `/home/zj/Downloads/base-3.14.12.4/src'
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
