Is there any way to specify that CA delivery of updates from certain
records should be prioritized over other records on the same ioc?
I've got an application where a bunch of ai's are processed at 10Hz and
some relatively big (for us) waveforms are processed at about 0.3-0.5
Hz. The ioc is not heavily loaded and all record processing seems to
happen in a timely way, but from the client end (EDM) the "fast" records
all pause for ~0.5 sec whenever the waveforms push out their CA updates.
The ai's are already being processed at a higher priority, but this
doesn't seem to help their updates get pushed out with higher priority.
Is there some tinkering I can do with the priorities of the CA threads
to get what I want? How can I tell which thread will get which record
updates? Is there something more obvious I'm missing?
--Brian
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
"The urge to save humanity is almost always only a false-face
for the urge to rule it."
-- H. L. Mencken
- Re: Prioritizing Channel Access per Record? Ralph Lange
- RE: Prioritizing Channel Access per Record? Mark Rivers
Re: Installing EPICS on the Raspberry Pi Pete Jemian
<2014>
RE: Recommended practice for cvtRecord chain initialization Emmanuel Mayssat
<2014>
