Dear All,
Kindly help.
1. How to prevent sequencer from stop, when some PVs get disconnect(without making this a new state) and sequencer should be resumed when PV is available? 2. How to check if particular PV is connected, in sequencer?
3. How to run multiple ioc(it may be soft or hard, having sequencer program ) on a single linux machine(Fedora 19). I am getting warning when running multiple IOC machine. similar to ...
cas warning : configure TCP port was unavailable cas warning : using dynamically assigned TCP port 56892 cas warning : but now two or more severs share the same UDP port cas warning : Depending on your IP kernel this server may not be cas warning : reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
I found some mail trail online but could not get straight way. I also tried by putting firewall off.
4. How to monitor a passive record even it has same value after update.(as camonitor do not show/reflected same value update in pv ).
I am using Epics base-3.14.12.3 Sequencer seq-2.1.16 OS: Linux Fedora 19 64bit
I have following settings. export EPICS_ROOT=/home/ganesh/epics export EPICS_HOST_ARCH=linux-x86_64 export EPICS_BASE=$EPICS_ROOT/base-3.14.12.3 export EPICS_EXTENSIONS=$EPICS_ROOT/extensions export EPICS_CA_ADDR_LIST="192.168.8.2 192.168.8.3 192.168.8.4 192.168.8.5" export MOTIF_LIB=/usr/lib64/
export SEQ=$EPICS_ROOT/extensions/seq-2.1.16 export PATH=/sbin:/bin:/usr/sbin:/usr/bin:$file:$EPICS_ROOT/base-3.14.12.3/bin/linux-x86_64:/bin/linux-x86_64 export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
Thanks and Regards
Ganesh
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
Re: Prioritizing Channel Access per Record? Andrew Johnson
css bundles issues Chen Xue
<2014>
NIKHEF hall probes Pierrick Hanlet
Multiple Queries(on Sequencer and IOC) Ganesh Jangir
<2014>
