On 03/18/2014 12:00 PM, Ralph Lange wrote:
> Please check that you have no database links that would pull "fast" and
> "slow" records into the same lock set.
The IOC shell 'dblsr' command shows you the IOC's lock-sets.
'dblsr * 1' will print all the lock-sets and their members, while 'dblrs
* 2' shows you the links between the records as well. Unfortunately the
output is a bit noisy. You can use a specific record name instead of the
* to see just the lock-set containing that record.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Prioritizing Channel Access per Record? Brian Bevins
- RE: Prioritizing Channel Access per Record? Mark Rivers
- Re: Prioritizing Channel Access per Record? Brian Bevins
- Re: Prioritizing Channel Access per Record? Ralph Lange
Multiple Queries(on Sequencer and IOC) Ganesh Jangir
<2014>
<2014>
