1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: MEDM: Passing PV Values to Shell Commands
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Cc: "Poff, Mark A" <[email protected]>
Date: Fri, 18 Apr 2014 18:44:17 +0000
Andrew,
Thanks for the suggestion and it seems like it should work - but after a considerable amount of trial and error I’m still not getting it.  For what it’s worth, I’m on a Linux system.  In the MEDM display’s Shell Command ‘Command’ field I put the executable name - foo.exe - and in the ‘Arguments’ field I put the line you recommend, echo ‘caget -t myPV’, where myPV is the target PV name.  This produces an error: “foo.exe: line 1: <myPVvalue>: command not found”, where <myPVvalue> is the current value of the PV.  No variation of the caget command I’ve tried produces the desired result of passing the value of myPV to foo.exe.  I can’t get this to work on the Linux command line, either.  By any chance, do you have any other suggestions?
-----Original Message-----
Sent: Friday, April 18, 2014 11:25 AM
To: Poff, Mark A; [email protected]
Subject: Re: MEDM: Passing PV Values to Shell Commands
Hi Mark,
On 04/18/2014 09:23 AM, Poff, Mark A wrote:
> Is it possible to pass a PV value as the argument of a program call
> from a MEDM Shell Command button?  It seems like that would be a
> useful capability, but I can’t find any reference to it.  Somebody
> posted this question in Tech-Talk for EDM in 2004 (“EDM: Passing PV
> values to shell
> commands”) but it doesn’t appear that the question was ever addressed.
> Can anybody tell me whether this capability exists and if so, the syntax?
That's a great question. The answer is not directly, but you can have the user select a PV from any widget on the display, and if you make the shell command pass that through `caget -t` you can convert the name into the PV's value before calling your program.
The Shell Command widget supports embedding the &P operator from the Execute Menu command[1] which prompts the user to point to the PV to be named before executing the command string.
Example: I create a Shell Command widget with a command set to
    echo `caget -t &P`
I also put at least one other PV on the screen. When I click the button, the cursor changes to prompt me to click on a widget that will provide the PV name. The caget command is then executed on that PV, and the value returned gets echoed on the terminal where I started medm.
Of course if your PV name is fixed you don't have to use the &P part at all, you can just name it directly in the caget call:
    echo `caget -t myPV`
Hope this helps,
- Andrew
[1]
http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/MEDM/MEDM.html#ExecuteMenu
Advertising may be described as the science of arresting the human intelligence long enough to get money from it. -- Stephen Leacock
Re: MEDM: Passing PV Values to Shell Commands Andrew Johnson
MEDM: Passing PV Values to Shell Commands Poff, Mark A
Prev: Re: MEDM: Passing PV Values to Shell Commands Andrew Johnson
Next: Re: MEDM: Passing PV Values to Shell Commands Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
