1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Dependency issue with shared database templates unless using "make clean"
Cc: "<[email protected]>" <[email protected]>
Date: Wed, 11 Jun 2014 16:09:39 +0000
Hello Andrew:
Yes, that's exactly what we need.
Thanks for reading the release notes for me.
Sorry that you had to read the release notes for me.
-Kay
On Jun 11, 2014, at 11:28 AM, Andrew Johnson <[email protected]>
 wrote:
> Hello Kay,
> Janet has made a number of changes to the dependency rules including
> those for templates since the 3.14.12.2 release that you appear to be
> using. I think we already did what you are suggesting - I just tried
> adding an external template file to a .substitutions file using the
> 3.14.12.3 release of Base and the generated .db.d file has the full
> path-name to the template file in it.
> The Release Notes for 3.14.12.3 included the following item which I
> think describes this issue:
>> Build problem with db dependencies
>> The dependency output for .db and .acf files created by
>> makeDbDepends.pl did not show the directories of the depended
>> files. The makeDbDepends.pl script has been replaced by mkmf.pl
>> for this purpose after modifying it to accept multiple -I
>> include directory options and more than one source file on the
>> command line. The makeDbDepends.pl script has been removed from Base.
> HTH,
> - Andrew
Dependency issue with shared database templates unless using "make clean" Kasemir, Kay
Re: Dependency issue with shared database templates unless using "make clean" Andrew Johnson
Prev: Re: Dependency issue with shared database templates unless using "make clean" Benjamin Franksen
Next: lakeshore 336/350 support Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Dependency issue with shared database templates unless using "make clean" Andrew Johnson
Next: Re: Dependency issue with shared database templates unless using "make clean" Benjamin Franksen
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
