Subject: |
Re: Dependency issue with shared database templates unless using "make clean" |
Andrew Johnson <[email protected]> |
To: |
Date: |
Wed, 11 Jun 2014 10:28:25 -0500 |
Hello Kay,
Janet has made a number of changes to the dependency rules including
those for templates since the 3.14.12.2 release that you appear to be
using. I think we already did what you are suggesting - I just tried
adding an external template file to a .substitutions file using the
3.14.12.3 release of Base and the generated .db.d file has the full
path-name to the template file in it.
The Release Notes for 3.14.12.3 included the following item which I
think describes this issue:
> Build problem with db dependencies
> The dependency output for .db and .acf files created by
> makeDbDepends.pl did not show the directories of the depended
> files. The makeDbDepends.pl script has been replaced by mkmf.pl
> for this purpose after modifying it to accept multiple -I
> include directory options and more than one source file on the
> command line. The makeDbDepends.pl script has been removed from Base.
HTH,
- Andrew
On 06/11/2014 09:53 AM, Kasemir, Kay wrote:
> Hi:
> We have certain database templates that are shared, and run into a problem with the make system when trying to re-build them without a prior "make clean". As the project grows, it's very inconvenient that every change requires a full rebuild.
> Assume we have some example.template in a shared location:
> /path/to/my/support/example/db/example.template
> In the configure/RELEASE file of a new application, we define its path:
> # Where the shared templates are
> SUPPORT_EXAMPLE=/path/to/my/support/example
> In the application's Db directory, we have my_database.substitutions:
> file example.template
> .. and in the Makefile there's
> TOP=../..
> include $(TOP)/configure/CONFIG
> DB += my_database.db
> include $(TOP)/configure/RULES
> A fresh build works OK:
> $ make
> perl ......R3.14.12.2/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
> mkdir O.Common
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
> make[1]: Entering directory `....xxxxApp/Db/O.linux-x86_64'
> echo "../O.Common/my_database.db : " >> my_database.db.d
> Inflating database from ../my_database.substitutions
> msi -I. -I.. -I ../../../db -I/home/controls/epics/R3.14.12.2/base/db -I/path/to/my/support/example/db -S../my_database.substitutions > my_database.tmp
> mv my_database.tmp ../O.Common/my_database.db
> Installing created db file ../../../db/my_database.db
> But when trying to run 'make' again, this fails:
> $ make
> make[1]: *** No rule to make target `example.template', needed by `../O.Common/my_database.db'. Stop.
> The problem seems to be that makeDbDepends.pl, called from RULES.Db, creates a dependency file like this:
> $ cat O.linux-x86_64/my_database.db.d
> ../O.Common/my_database.db: example.template
> When msi is called, it received command line options like "-I/path/to/my/support/example/db" that allow it to find all dependencies, but when 'make' is looking at the my_database.db.d dependency file, it only has "example.template" without any idea where to find it, so it rightly complains "No rule to make..".
> Would it make sense to invoke makeDbDepends.pl with options similar to the msi invocation, and update it to write the full path to all dependencies into the dependency file?
> That way, makeDbDepends.pl could create a dependency file that lists the complete path names, i.e.
> ../O.Common/my_database.db: /path/to/my/support/example/db/example.template
> and then make would be happy.
> Thanks,
> Kay
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Dependency issue with shared database templates unless using "make clean" Kasemir, Kay
- Dependency issue with shared database templates unless using "make clean" Kasemir, Kay
Re: Dependency issue with shared database templates unless using "make clean" Benjamin Franksen
<2014>
<2014>
