1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: calc R3-4
Date: Tue, 1 Jul 2014 19:05:41 +0000
Dear folks,
calc R3-4 is now available here:
http://www.aps.anl.gov/bcda/synApps/calc/calc.html
Release 3-4
  • acalcout record: new functions, better treatment of subranges:
    • IXMAX: index of largest array element
    • IXMIN: index of smallest array element
    • IXZ: index of first zero crossing in array
    • IXNZ: index of first nonzero array element
    • FITQ, FITMQ: fit to quadratic and optionally return fit coefficients. (Replacements for deprecated FITPOLY, FITMPOLY.)
    • CAT: concatenate array subranges, or an array subrange and a double.
    • operators ^ and ** reimplemented to permit noninteger exponents.
    • acalcout expressions now maintain array extents on the stack, so, for example, the _expression_ avg(aa[1,10]) really is an average of just aa[1,10]. Previously, avg(aa[1,10]) actually performed sum(aa[1,10])/arraySize. Now it does sum(aa[1,10])/10.
  • scalcout and transform records: operators ^ and ** reimplemented to permit noninteger exponents.
  • use Perl's ExtUtils::Command to concatenate .dbd files, instead of local cat.pl. Left old stuff in place, for now, in case someone has a problem with the new method.
  • Minor improvements in interp
  • When an scalcout fails to fetch a string field, give an informative error message.
Release 3-3
  • The transform record now supports expressions with user-specified variable names. For example, instead of the _expression_ "a-b/2", you could arrange to write "$center+$size/2". Variable names are specified using the CMTx fields. The sizes of calc fields have been increased from 80 to 120 to better accommodate variable names.  (See http://www.aps.anl.gov/bcda/synApps/calc/transformRecord.html#Expressions)
  • Make it easier to add 10 more usercalcs by writing, e.g., userCalcouts10more.db
Prev: autosave R5-4 Mooney, Tim M.
Next: sscan records Christian Pauly
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
