I think it might be possible to do this with a format converter, but, in a cursory look at the docs, the answer didn't jump out at me. You could do it with an scalcout record.
If you can get the string " 000024015" into the scalcout record's AA field, the calc _expression_ "aa[0,2]+":"+aa[3,4]+":"+aa[5,6]+":"+aa[7,8]" will put "000:02:40:15" in the SVAL field.
Tim Mooney
I have a timer device that provides data over a RS232 serial interface. I’m using StreamDevice to grab the data and publish as PVs. The data contains several times. All the times come in as an ASCII string containing days, hours, minutes
and seconds and I'm writing them to stringin PVs. However, the data does not contain any separators, so the data coming in looks something like 000024015 (i.e. 000 days, 02 hours, 40 minutes, 15 seconds). I know the ‘in’ command needs to match the incoming
data exactly or else it is discarded, but is there a way to add formatting to the PV that is NOT in the data? All I want to do is add a ‘:’ separator between each part, so the PV value will be like 000:02:40:15. Any suggestions?
Thanks!
- Formatting StreamDevice input Elmer Pensack
Re: EPICS alarming on VAL != X Maren Purves
<2014>
RE: Formatting StreamDevice input Mazanec Tomáš
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
