On 07/25/2014 07:05 AM, Benjamin Franksen wrote:
> On Thursday 24 July 2014 11:27:24 Andrew Johnson wrote:
>> If
>> you want to stop changes for a while, disable record processing using
>> SDIS & DISV.
> I don't think this will prevent the VAL from changing e.g. due to put
> operations, or does it?
Ahh, for that you also have to set DISP (which I was thinking about when
I wrote that but forgot to mention).
On 07/25/2014 07:34 AM, Dirk Zimoch wrote:
> Does it make sense to change the code to:
> if (prec->drvh >= prec->drvl)
> And change the default values so that DRVL>DRVH (e.g. DRVL=0, DRVH=-1)
> Then nothing would change if the db designer ignores the fields.
But a database that dynamically switches the limits on & off by writing
to DRVL and/or DRVH (depending on machine mode say) could break.
On 07/25/2014 08:58 AM, Benjamin Franksen wrote:
> On Friday 25 July 2014 14:34:13 Dirk Zimoch wrote:
>> Another alternative is to set default values DRVL=-Inf and DRVH=Inf.
> I like this idea. It precisely captures the desired default behaviour
> w/o imposing any artificial limitation. I guess the 'if (prec->drvh >
> prec->drvl)' hack was from before +/-Inf was standardized.
I still think there may be databases out there that rely on being able
to set DRVH and DRVL to the same value to disable the limit checks.
Changing the DRVH > DRVL test to DRVH >= DRVL will break those IOC
databases.
> BTW, does dbLoadRecords understand +/-Inf in a db file? Does
> dbLoadDatabase in a record type field definition's "initial" property?
I believe so, it worked from dbLoadRecords when I tried it on Linux just
now. However it's more efficient to avoid doing the individual value
checks at all by defaulting DRHV to DRVL.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- EPICS alarming on VAL != X Jameson Graef Rollins
- Re: EPICS alarming on VAL != X Benjamin Franksen
- Re: EPICS alarming on VAL != X Andrew Johnson
can't see epicsqt widgets in QT designer Hansen
<2014>
Re: EPICS alarming on VAL != X Jameson Graef Rollins
<2014>
