1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: New version of LabVIEW-EPICS-interface CA Lab 1.5.0.5 - Events are working at Linux again
To: tech-talk <[email protected]>
Date: Fri, 1 Aug 2014 10:36:32 +0200
We are happy to bring you the improved version of our
LabVIEW-EPICS-interface CA Lab 1.5.0.5!
Good news for all Linux users! User events are working again!
http://www-csr.bessy.de/control/SoftDist/CA_Lab/
Change-log of CA Lab
V1.5.0.5 (Released: August 2014)
  + Environment variable for redirecting debug window output to a file
        CALAB_NODBG = PATH_NAME_OF_LOG_FILE
  + Environment variable for switching off monitoring EPICS variables
        This is useful to avoid permanent open network ports(CompactRIO)
        CALAB_POLLING = TRUE
        (CA Lab looks only if CALAB_POLLING is defined. The value does
        not matter. Events and synchronisation are disabled if you use
        this polling mode.)
  + Added CALAB_NODBG and CALAB_POLLING to CaLabInfo
  # Non-blocking mutexes to avoid freezing
  # Improved CaLabPut to run more smoothly
  # Detection of empty PV names in CaLabPut
  # Good news for all Linux users: CaLabEvent.vi is working again
    Please link the CA Lab library without the option "-llv"
All suggestions and comments are welcome!
Cheers
Carsten
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: RE: 回复:epicsqt on arm board Emmanuel Mayssat
Next: =?gb18030?b?u9i4tKO6IFJFOiC72Li0o7plcGljc3F0IG9uIGFy?==?gb18030?b?bSBib2FyZA==?= =?gb18030?b?SGFuc2Vu?=
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Recommended Control HWs for High Voltage Platform Silver
Next: mrfioc2 release 2.0.3 Michael Davidsaver
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
