Hi all, Finally, I find what's the problem, because the localhost(127.0.0.1) is not up. now it works well! so I appreciate all your help. Thank you very much. ------------------ 原始邮件 ------------------ 发件人: "Emmanuel Mayssat";<[email protected]>; 发送时间: 2014年8月1日(星期五) 中午1:28 抄送: "Andrew Rhyder"<[email protected]>; 主题: RE: 回复:epicsqt on arm board Hansen, We need more information: Which board are you using? What OS? Did you cross compile with Qt creator? If so which toolchain and which version of Qt are you using? The problem you have seem to be coming from your network configuration though or your EPICS environment. How many network interfaces to you have? What about your EPICS environment (env | grep EPICS )? Regards, -- Emmanuel From: [email protected] To: [email protected]; [email protected] Subject: 回复:epicsqt on arm board Date: Fri, 1 Aug 2014 10:47:40 +0800 Hi all, I think it's the problem that run caclient and IOC on the same board, any document introduce how to implement it? when I run epicsqt app , always got such message:
------------------ 原始邮件 ------------------ Hi all, I nearly succeed in playing epicsqt on arm board. when I put epicsqt app with IOC on the same board, the epicsqt app can't detect the pv change, but when I put the epicsqt app on another arm board, the epicsqt app can automatically detect the pv change. anybody has idea about it? ------------------ Original ------------------ From: "我自己的邮箱";<[email protected]>; Date: Tue, Jul 29, 2014 08:58 PM To: "tech-talk"<[email protected]>; Subject: epicsqt on arm board Hi, Anybody compile epicsqt on arm using cross compiler?
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
