Subject: |
Ai device supports: smoothing issue when receiving FP values |
Ralph Lange <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Wed, 06 Aug 2014 11:42:32 +0200 |
All,
There's an issue that has been identified and fixed recently, which
affects device supports for the analog input record that handle
incoming float and double values. [1]
Possibly affected: device support for field buses, intelligent
devices, PLCs, serial connections, ...
If you are maintaining such a device support, please read the
details and take action, if necessary.
If not, stay calm and carry on.
Cheers,
~Ralph
Details:
Any device support for the analog input record that handles floating
point values (e.g., IEEE 754) being sent by the device has to apply
the smoothing algorithm in the device support, as the record support
does this as part of converting from integer to double, which is not
used in case the device sends floating point values.
Typically, such a code snipped would look like:
/* Apply smoothing algorithm */
if (prec->smoo != 0.0)
prec->val = val * (1.00 - prec->smoo)
+ (prec->val * prec->smoo);
else
prec->val = val;
This breaks if the record's value is not finite (i.e., NaN, +inf, or
-inf) as the formula will never return a finite value, and the
record is stuck at NaN/+inf/-inf and will never get back to a finite
value, no matter what the device sends.
A possible simple fix is extending the condition:
#include <epicsMath.h>
if (prec->smoo != 0.0 && finite(prec->val))
else
prec->val = val;
Please check and fix your code if you expect devices to be capable
of sending non-finite numbers.
[1] https://bugs.launchpad.net/epics-base/+bug/1351332
Re: error of beacon Ralph Lange
RE: st.cmd -- Line 30 -- Command seq not found. Mark Rivers
<2014>
Re: st.cmd -- Line 30 -- Command seq not found. Benjamin Franksen
VDCT priya tiwari
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
