Hi Tom,
Since nobody else has bitten yet...
Have you considered using http: to deliver your screens to the users?
That appears to be the way that some sites are going, as it solves the
shared workspace problem and might simplify the soft-link management.
You might even be able to do some of your version selection on the
server-side instead of using soft-links if you wanted to.
That said I have no experience with doing this at all, so you'll have to
find out how to go about that from the real CS-Studio guys.
- Andrew
On 08/11/2014 09:30 AM, [email protected] wrote:
> Hi all,
> We're looking at how we should launch CS-Studio BOY screens on beamlines and machine, and have the following requirements:
> 1) If an IOC has a database template instance from a motor version 6-5, the screens for that IOC should come from motor 6-5.
> 2) One insertion device may have all its IOCs pointing at motor 6-5, but another may be at 6-4 or 6-2.
> 3) A user may want to launch sets of screens for many insertion devices at the same time.
> The same is true for beamlines, front ends, and other technical areas: a user may start at a high level screen, and drill down to a different version of the motor screen depending which IOC that component is on.
> For EDM we simply launched a new EDM for each insertion device with its own search path, but doing the same with CS-Studio would be quite resource hungry. We have had more than 20 instances of EDM running at once, and I wouldn't like to do the same with java virtual machines.
> We have come up with a proposal that would work for us:
> * Create a project for each insertion device (and beamline etc.) with soft links to the versions of each support module it uses
> * Run a command that tells the current running CS-Studio to import that project to the user's workspace and run a screen within it
> * We could then have one CS-Studio instance, and let each user have their own workspace, but manage the locations of the projects within it ourselves
> The eclipse navigator file structure would look like this:
> workspace/ # located in user's home directory
> CSS/
> ID1/ # Eclipse project pointing to /dls_sw/.../ID1/2-0
> motor/ # Soft link in /dls_sw/.../ID1/2-0 pointint to /dls_sw/.../motor/6-5
> ID2/ # Eclipse project pointing to /dls_sw/.../ID2/3-0
> motor/ # Soft link in /dls_sw/.../ID1/3-0 pointint to /dls_sw/.../motor/6-2
> Has anyone else done anything similar? How do other sites launch CS-Studio BOY screens?
> Thanks,
> Tom Cobb
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Launching CS-Studio BOY screens Michael Davidsaver
- Launching CS-Studio BOY screens tom.cobb
RE: New to EPICS - system design questions Ryan Pierce
How to tag soft channels as undefined/disconnected Kellee Summers
<2014>
<2014>
