1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Processing a record a in loop
To: "Pearson, Matthew R." <[email protected]>
Cc: David Michel <[email protected]>, EPICS mailing list <[email protected]>
Date: Wed, 3 Sep 2014 12:44:20 -0700
On Sep 3, 2014, at 8:21 AM, Pearson, Matthew R. <[email protected]> wrote:
> Hi David,
> Trying setting the mask to 0xFF, which will mean you'll see everything (and it will be very verbose). Then you can tweak the mask to just see what you want:
> asynSetTraceMask("PORT", 0, 0xFF)
That will display a lot of asyn internal messages.  To just see I/O and error messages:
asynSetTraceMask("PORT", 0, 0x9)
> asynSetTraceIOMask("PORT", 0, 0xFF)
That will display raw and C-escaped, and hexadecimal versions of the I/O bytes.  For a standard ASCII message based device you’ll likely be happier with:
asynSetTraceIOMask("PORT", 0, 0x2)
> (where the 0 is the asyn address).
> You can also set the TPRO field to 1 in that record, which will cause a string to be printed on the IOC shell whenever that record is processed (although it might just do it at the SCAN rate, and not reflect any ongoing processing. Not sure).
> One trick is to attach an asynRecord to the port, and use a GUI to set the trace bits on and off. It's much easier than typing it at the IOC shell (especially once it's already printing stuff).
> Cheers,
> Matt
Eric Norum
[email protected]
Processing a record a in loop David Michel
RE: Processing a record a in loop Mark Rivers
Re: Processing a record a in loop David Michel
Re: Processing a record a in loop Pearson, Matthew R.
Prev: RE: synApps_5_7 build error on Windows 8.1 x64 freddie.akeroyd
Next: RE: Processing a record a in loop Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Processing a record a in loop Andrew Johnson
Next: RE: Processing a record a in loop Dalesio, Leo
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
