1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: -D__STDC_VERSION__=199901L
To: "[email protected] list" <[email protected]>
Date: Fri, 5 Sep 2014 23:40:17 +0000
I noticed that epicsUInt64 is not defined on my 64-bit system. In epicsTypes.h I see:
#if __STDC_VERSION__ >= 199901L
    typedef int8_t          epicsInt8;
    typedef uint8_t         epicsUInt8;
    typedef int16_t         epicsInt16;
    typedef uint16_t        epicsUInt16;
    typedef epicsUInt16     epicsEnum16;
    typedef int32_t         epicsInt32;
    typedef uint32_t        epicsUInt32;
    typedef int64_t         epicsInt64;
    typedef uint64_t        epicsUInt64;
#else
    typedef char            epicsInt8;
    typedef unsigned char   epicsUInt8;
    typedef short           epicsInt16;
    typedef unsigned short  epicsUInt16;
    typedef int             epicsInt32;
    typedef unsigned int    epicsUInt32;
#endif
So I tried setting -D__STDC_VERSION__=199901L in:
configure/os/CONFIG.Common.linuxCommon
But I suspect that's the wrong way to do it, because base failed to compile:
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D__STDC_VERSION__=199901L           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include        ../cac.cpp
In file included from ../comBuf.h:34,
                 from ../cac.h:44,
                 from ../cac.cpp:39:
../../../include/osiWireFormat.h: In function ‘void WireSet(const T&, epicsUInt8*) [with T = char]’:
../comBuf.h:237:   instantiated from ‘unsigned int comBuf::push(const T*, unsigned int) [with T = char]’
../comQueSend.h:123:   instantiated from ‘void comQueSend::push(const T*, unsigned int) [with T = char]’
../comQueSend.h:206:   instantiated from here
../../../include/osiWireFormat.h:208: error: ‘tmp’ has incomplete type
But I'm sure many people are using C99. Any ideas?
Cheers,
Matt
ps.
[mkp@bl99-dassrv1 base]$ rpm -q libstdc++
libstdc++-4.4.7-3.el6.x86_64
[mkp@bl99-dassrv1 base]$ g++ -v
Using built-in specs.
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --enable-libgcj-multifile --enable-java-maintainer-mode --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libjava-multilib --with-ppl --with-cloog --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
Thread model: posix
gcc version 4.4.7 20120313 (Red Hat 4.4.7-3) (GCC)
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
Re: -D__STDC_VERSION__=199901L matthieu bec
Re: -D__STDC_VERSION__=199901L Johnson, Andrew N.
Prev: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin Andrew Johnson
Next: Re: -D__STDC_VERSION__=199901L matthieu bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
