1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: check what is caput doing
To: [email protected]
Date: Wed, 10 Sep 2014 09:11:37 +0200
Dear all,
I have an epics installation. Things are working fine, I can store data to the DB and access to it using CSS. Now I an checking the command line utilities. caget prints the correct value of the numbers but caput is not working fine.
It doesn't print an error message. Just says that the new value I pass to caput is the the same as the old value i get with caget.
Where should I look to see what is happening?
Thanks in advance for your help
Zunbeltz
Dr. Zunbeltz Izaola
Accelerator Physics Group
ESS-Bilbao
Re: check what is caput doing Ralph Lange
Prev: EPICSQt version 2.9.0 released Andrew Rhyder
Next: Re: check what is caput doing Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
