1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Keithley 2400 communication
To: [email protected]
Date: Thu, 11 Sep 2014 07:28:11 -0700
Priya:
If you are using streamDevice, and I recommend that you do, you can put all of the output string commands into a single streamDevice protocol. The "READ?" command appears to be a query that will invoke a response from the device. In that case, you can also use an 'in' command to acquire the reply, and format it into the respective record:
RESET {
   out "*RST";
   out "SOUR:FUNC VOLT";
   out "SOUR:VOLT:MODE FIX";
   out "SOUR:VOLT:RANG 20";
   out "SOUR:VOLT:LEV 10";
   out "OUTP ON";
   out "READ?";
   in "%f";
I think you would probably not want to reset the device each time you read from it, so splitting the READ query into a separate protocol attached to a separate record (ai, presumably) probably makes more sense.
Definitely see the streamDevice online docs for all of the details.
Rod Nussbaumer
Control System Group, TRIUMF
Vancouver, Canada
On 09/11/2014 06:48 AM, Mooney, Tim M. wrote:
Hi Priya,
A quick way to do this would be to attach an asyn record to the serial
port, and use a sseq record to control and send strings to it.
record(sseq, "doReset") {
field(STR1, "Read")
field(LNK1, "asynrecord.TMOD")
field(STR2, "*RST")
field(LNK2, "asynrecord.AOUT CA")
field(WAIT2, "Wait")
field(STR3, ":SOUR:FUNC VOLT")
field(LNK3, "asynrecord.AOUT CA")
field(WAIT3, "Wait")
field(STR7, ":OUTP ON")
field(LNK7, "asynrecord.AOUT CA")
field(WAIT7, "Wait")
field(STR8, "Write/Read")
field(LNK8, "asynrecord.TMOD")
field(STR9, ":READ?")
field(LNK9, "asynrecord.AOUT CA")
field(WAIT9, "Wait")
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
behalf of priya tiwari [[email protected]]
*Sent:* Thursday, September 11, 2014 2:19 AM
*To:* [email protected]
*Subject:* Keithley 2400 communication
Hello,
I am trying communication with KEITHLEY 2400 on serial port(RS-232).I
sent command "*IDN?" it has performed very well and i got the output.
i want to reset the device and the commands are
*RST
:SOUR:FUNC VOLT
:SOUR:VOLT:MODE FIX
:SOUR:VOLT:RANG 20
:SOUR:VOLT:LEV 10
:OUTP ON
:READ?
now,How to write program in VDCT for performing all commands
sequentially.Actually i have no idea about this.please help me....
Q.2: How to send commands to device at run time in VDCT?
what is the format of
caput? on that time
Thanks in advance
Re: Keithley 2400 communication priya tiwari
RE: Keithley 2400 communication Mooney, Tim M.
Prev: RE: Keithley 2400 communication Mooney, Tim M.
Next: RE: msi missing when isntalling synApps Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Keithley 2400 communication priya tiwari
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
