Hello all, I am trying to perform source (I or V) sweeps and measure the sense values. The sweep needs to run an infinite amount of times (for the keithley source max is around 1e38 times ). This I can do by setting the trigger arm count. However I need to perform measurements during the sweep which I am having trouble with. Also I need to clear the buffer during this sweep cycle. So my question is this. Is there something similar to goto or an if/else that i can use in the protocol file to achieve this i.e read measurement-> clear buffer-> repeat, after the sweep has started. Any help would be greatly appreciated. Thank you Regards, Ali ------------------------------------------------------ Alireza Panna University of Maryland, College Park
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
