1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: stream device with Keithley 2410
To: Alireza Panna <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 12 Sep 2014 13:03:02 +0000
How quickly are you triggering it?  If it is 10Hz or less you may be able to just have a periodically processed record to read the value.   That forward links to the record that clears the buffer.  You don't do this in the protocol file, but rather in the database.
With StreamDevice you can also set the record that reads the value to SCAN=I/O Intr.  Then it will poll for a new reading and whenever it gets one it will process your records.
If the triggering is very fast then you may need read a block of values into a waveform record.
From: [email protected] [[email protected]] on behalf of Alireza Panna [[email protected]]
Sent: Thursday, September 11, 2014 7:20 PM
To: [email protected]
Subject: stream device with Keithley 2410
Hello all,
I am trying to perform source (I or V) sweeps  and measure the sense values. The sweep needs to run an infinite amount of times (for the keithley source max is around 1e38 times ). This I can do by setting the trigger arm count. However I need to perform measurements during the sweep which I am having trouble with. Also I need to clear the buffer during this sweep cycle.
So my question is this. Is there something similar to  goto or an if/else that i can use in the protocol file to achieve this i.e read measurement-> clear buffer-> repeat, after the sweep has started.
Any help would be greatly appreciated.
Thank you
Ali
Alireza Panna
University of Maryland, College Park
stream device with Keithley 2410 Alireza Panna
Prev: build labca 岳敏
Next: Re: build labca Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: stream device with Keithley 2410 Alireza Panna
Next: build labca 岳敏
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
