1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is RULES_JAVA broken?
To: <[email protected]>
Date: Tue, 16 Sep 2014 21:40:52 +0200
Am Dienstag, 16. September 2014, 09:50:44 schrieb J. Lewis Muir:
> On 9/15/14, 11:00 PM, Nerses Gevorgyan wrote:
> > The Makefile is quite simple.
> > vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
> > TOP=../..
> > JAVA_DIR = ~rafopar/Apps/Java/jdk1.7.0_67
> I've never used RULES_JAVA, so I'm not commenting on any of your
> reported problems, except I will say that your use of a tilde character
> ('~') in your JAVA_DIR path might be a problem.  That is normally a
> special syntax recognized by certain shells that will be expanded to a
> user's home directory.  That might not work as you're expecting in GNU
> Make.  I suggest replacing that with an absolute path.
Hi Lewis
Gnu make by default uses /bin/sh to execute recipes (one invocation per line),
which should be a posix conformant(*) shell and thus support tilde expansion.
For make itself, the tilde is just another character with no special meaning.
The problem is that makefiles sometimes do non-trivial processing of make
variables before using them in recipes, where they (hopefully) get expanded by
the shell. This is very common in EPICS. If this processing is written in a
way that, for instance, expects an absolute path to start with a '/' then this
processing will fail even though the shell will expand it to one.
So, in practice, +1 to your recommendation.
Cheers
Ben
(*) Interestingly, neither my spell checker nor Webster knows this word, but
I've read it many, many times in English texts so it can't be completely
wrong, or can it?
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Is RULES_JAVA broken? J. Lewis Muir
Is RULES_JAVA broken? Nerses Gevorgyan
Prev: Re: Is RULES_JAVA broken? J. Lewis Muir
Next: Re: Is RULES_JAVA broken? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Is RULES_JAVA broken? Nerses Gevorgyan
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
