Hello Steve,
Are you sure that you do not want one record for each battery?
I would expect one bo record to switch one battery on or off:
record (bo, "Battery$(N)OnOff")
field (DTYP, "stream")
field (OUT, "Battery.proto OnOff($(N)) dev”)
OnOff {
Battery %{On|Off} \$1";
in "OK";
@mismatch { in "Error:%(Battery\$1Error)s”; }
(Disadvantage: Last error stays in error record when everything is OK.)
If you have a fixed and known set of error messages, you can also
redirect to an mbbi Error record like this:
in "%(Battery\$1Error){OK|Error: message1|Error: message2}";
Or do you select battery x out of n?
Dirk
On 17.09.2014 18:22, Goff, Steven J wrote:
Hello,
I am trying to understand how to setup a particular command in a
protocol file.
The command looks like this:
Battery On “number”
And the command returns either: “OK” or ”Error: err msg”.
I think my protocol file might look like this:
Battery
Out “Battery On %d”;
And my db file would look like this:
Record (longin, “batteryOn”)
Field(DTYP, “stream”)
Field(INP, “myDev.proto Battery dev”)
How do I get the status that the command returns?
I want to do something like
Battery
In “%s”;
But I am already using an input for the battery number. So how do I do
both?
Thanks In advance.
Steve Goff
- Stream device protocol files question? Goff, Steven J
RE: Stream device protocol files question? peter.owens
Re: Asyn Dirk Zimoch
<2014>
Sequencer web search lists out-dated sites Benjamin Franksen
<2014>
