1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: snmp error
To: <[email protected]>
Date: Fri, 19 Sep 2014 11:21:09 -0400
Which EPICS SNMP driver are you using?  I've written one some people use for Wiener ISEGs, but there are others.
Here's ours:
<https://groups.nscl.msu.edu/controls/#SNMP>
That's not an error response I can find grepping my code either.
On 9/19/2014 11:13 AM, Pierrick Hanlet wrote:
I've an error with snmp that I've never seen before and cannot find in tech-talk repositories.
I have some devices which I talk to via snmp.  I have no errors in compilation, nor starting
my (soft) IOC, however they occur for each record which attempts to make the snmp call.
When I use snmp v2c, the error message is:
Record [PVname] parsing response [No Such Instance currently exists at th] error!
When I use snmp v1, the error message is:
Record [PVname] parsing response [ NULL] error!
I'm on an SL6.4 machine and am using V 3.4.12.3
When I do a recursive grep on base, I cannot even find snippets of this error message.
An additional mystery is that the code hasn't changed and used to work when I was
running with SL5.7.
Any ideas?
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
John A. Priller             | Phone : (517) 908-7375
MSU Cyclotron Laboratory    | Fax   : (517) 908-7126
640 S. Shaw Lane room 1300D | Email : [email protected]
East Lansing, MI 48824      | Web   : http://people.nscl.msu.edu/~priller/
Prev: snmp error Pierrick Hanlet
Next: Building EPICS base in Windows mreza
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: snmp error Dirk Zimoch
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
