Hello All,
I just wanted to share my experience in building EPICS base in Windows 8.1 ,
Below is my system setting :
- OS : Windows 8.1 , 64 bit
- EPICS : Release R3.14.12
- Visual studio 2012
- Strawberry PERl
- GnuWin LibArchive
- GnuWin Patch
- COMODO Internet security
I followed all the steps which are available in this link "
http://www.aps.anl.gov/epics/base/win32.php "
but I got the following errors :
make: Entering directory `C:/EPICS/base-4'
make -C ./configure install
make[1]: Entering directory `C:/EPICS/base-4/configure'
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
make[2]: Entering directory `C:/EPICS/base-4/configure/O.win32-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `C:/EPICS/base-4/configure/O.win32-x86'
make[1]: Leaving directory `C:/EPICS/base-4/configure'
make -C ./src install
make[1]: Entering directory `C:/EPICS/base-4/src'
make -C ./tools install
make[2]: Entering directory `C:/EPICS/base-4/src/tools'
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory `C:/EPICS/base-4/src/tools/O.win32-x86'
make[3]: Leaving directory `C:/EPICS/base-4/src/tools/O.win32-x86'
make[2]: Leaving directory `C:/EPICS/base-4/src/tools'
make[1]: Leaving directory `C:/EPICS/base-4/src'
make: Leaving directory `C:/EPICS/base-4'
Then started making in debug mode and directed the messages to a text file :
C:\EPICS\base-4> make -d > out.txt
I found some interesting notes in the out.txt file which was creating
temporary batch files
and executing them as a process :
Creating temporary batch file C:\Users\P1\AppData\Local\Temp\make6180-1.bat
CreateProcess(C:\Users\P1\AppData\Local\Temp\make6180-1.bat,C:\Users\P1\AppData\Local\Temp\make6180-1.bat,...)
Putting child 0x025cbeb8 (../../../lib/perl/EPICS/Copy.pm) PID 39548768 on
the chain.
Live child 0x025cbeb8 (../../../lib/perl/EPICS/Copy.pm) PID 39548768
Main thread handle = 0x0000024c
Reaping losing child 0x025cbeb8 PID 39548768
Cleaning up temp batch file C:\Users\P1\AppData\Local\Temp\make6180-1.bat
Removing child 0x025cbeb8 PID 39548768 from chain.
Reaping losing child 0x0259fd60 PID 39554088
Removing child 0x0259fd60 PID 39554088 from chain.
Reaping losing child 0x025a07a8 PID 39721848
Removing child 0x025a07a8 PID 39721848 from chain.
Reaping losing child 0x0259f0c0 PID 39570192
Removing child 0x0259f0c0 PID 39570192 from chain.
Then I found that these batch files are somehow being banned from
execution the I looked at
the COMODO internet security logs and I found these files are being
considered as a threat
and partially limited .
Thus I disabled COMODO then tried again and the problem got solved .
Therefore if you are trying to build EPICS in Windows , before starting to
make it check your
system security software settings .
Note : With "Microsoft security essentials" you don't run into this problem.
With regards,
Reza
Triumf Control Group.
Re: snmp error John A. Priller
Re: EDM priya tiwari
<2014>
Problem with synApps installing Vlad Andrei Rusu
<2014>
