1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IOC server on windows or access a PV
To: "zunbeltz" <[email protected]>, <[email protected]>
Date: Fri, 3 Oct 2014 08:00:59 +0200
You could also implement really quickly an EPICS server in C# or any other .NET language which could easily serve any value you want over the network and then be read from any other EPICS client / server.
Check out our documentation here: http://sourceforge.net/p/epicssharp/wiki/server/
Sincerely,
Alain Bertrand
From: [email protected] [mailto:[email protected]] On Behalf Of zunbeltz
Sent: Thursday, October 02, 2014 21:49
To: [email protected]
Subject: IOC server on windows or access a PV
Dear all,
We need to pass some values, calculated from photographs, to the EPICS network from a windows machine.
Is it easy to install an IOC server in a windows machine?
If not, our idea is to create the PVs in an already running IOC server (on linux), and use caput tool (from the EPICS Extensions http://aps.anl.gov/epics/distributions/win32/index.php) to update the values.
Is it possible to create an  PV that is not associated with any hardware in a IOC server? Is it enough to add a record in the ioc.db file?
Thanks in advance for your help.
Zunbeltz
Dr. Zunbeltz Izaola
Accelerator Physics Group
ESS-Bilbao
IOC server on windows or access a PV zunbeltz
Prev: Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor Peter Linardakis
Next: Re: IOC server on windows or access a PV zunbeltz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOC server on windows or access a PV zunbeltz
Next: Re: IOC server on windows or access a PV Zunbeltz Izaola
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
