1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC server on windows or access a PV
To: [email protected]
Cc: [email protected]
Date: Fri, 03 Oct 2014 09:55:07 +0200
This was my thought.
Thanks
Zunbeltz
Xiaoqiang Wang <[email protected]> wrote:
>Dear Zunbeltz,
>For such a channel access server, the PV timestamp is given by the server where the PV is hosted.
>Best
>Xiaoqiang
>On 03 Oct 2014, at 09:31, zunbeltz <[email protected]> wrote:
>> Dear Xiaoquiang,
>> Thanks for the information.
>> What is important to me is also to have a proper timestamp for the PVs and I an not very confident on the windows machine.
>> If I install a portable channel access server, the timestamps of the PVs I serve there will be taken from the windows machine; am I right? If I have the server in other computer the timestamp of the uploaded PV will be given by that other server, not the "caput" operation I run in the windows; isn't it?
>> Best regards,
>> Zunbeltz
>> og., 2014.eko urrren 02a 22:13(e)an, Xiaoqiang Wang igorleak idatzi zuen:
>>> Hi,
>>> There is a 3rd choice: create the PV in portable channel access server.
>>> If your calculation code can be invoked with Python, be it a C extension or separate program (using subprocess module).
>>> This can be easy to write using PCASpy[1] extension.
>>> Best
>>> Xiaoqiang
>>> [1] https://pypi.python.org/pypi/pcaspy
>>> On 02 Oct 2014, at 21:48, zunbeltz <[email protected]> wrote:
>>>> Dear all,
>>>> We need to pass some values, calculated from photographs, to the EPICS network from a windows machine.
>>>> Is it easy to install an IOC server in a windows machine?
>>>> If not, our idea is to create the PVs in an already running IOC server (on linux), and use caput tool (from the EPICS Extensions http://aps.anl.gov/epics/distributions/win32/index.php) to update the values.
>>>> Is it possible to create an  PV that is not associated with any hardware in a IOC server? Is it enough to add a record in the ioc.db file?
>>>> Thanks in advance for your help.
>>>> Zunbeltz
>>>> Dr. Zunbeltz Izaola
>>>> Accelerator Physics Group
>>>> ESS-Bilbao
>> Dr. Zunbeltz Izaola
>> ESS-Bilbao
Prev: Re: IOC server on windows or access a PV Xiaoqiang Wang
Next: RE: Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: IOC server on windows or access a PV Bertrand Alain Gregor
Next: Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor Peter Linardakis
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
