1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: stumbled at the first softioc example
To: [email protected]
Date: Wed, 8 Oct 2014 18:10:44 +0800
Hi all,
I’m new to the epics world. I setup epics by this article.
But I didn’t get pv successful. After some search, I still don’t know why.
In the article, it set the env
export EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST=localhost
After start softIoc program, I use caget calc:a, cannot get anything
  Channel connect timed out: 'calc:a' not found.
And I also use the following command to make sure caget works, it seems OK.
 $ sudo tcpdump -i lo  -n -nn udp dst portrange 5064-5065
  02:32:13.408675 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.441478 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.505696 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.632719 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
So, I suspect the softIoc don’t listen the 5064 port.
  netstat -a | grep softIoc
but I find nothing.
What I can do now?
Thanks!
Sincerely,
HaveF
Re: stumbled at the first softioc example Michael Davidsaver
RE: stumbled at the first softioc example Mark Rivers
Prev: Re: Fanout to Sub Records in a Different IOC Causes Core Dump Hartman, Steven M.
Next: Job Opening at Helmholtz-Zentrum Berlin (HZB) Joachim Rahn
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fanout to Sub Records in a Different IOC Causes Core Dump Steven
Next: Re: stumbled at the first softioc example Michael Davidsaver
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
