1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stumbled at the first softioc example
To: [email protected]
Date: Wed, 08 Oct 2014 06:46:55 -0400
What do you see when you run the softIoc executable?  Normally you
should see "iocRun: All initialization complete" printed.
On 10/08/2014 06:10 AM, HaveF wrote:
> Hi all,
> I’m new to the epics world. I setup epics by this article
> <https://pubweb.bnl.gov/%7Emdavidsaver/epics-doc/epics-starting.html#_softioc>.
> But I didn’t get pv successful. After some search, I still don’t know why.
> In the article, it set the env
> export EPICS_CA_AUTO_ADDR_LIST=NO
> export EPICS_CA_ADDR_LIST=localhost
> After start softIoc program, I use |caget calc:a|, cannot get anything
> |  Channel connect timed out: 'calc:a' not found.
> And I also use the following command to make sure |caget| works, it
> seems OK.
> | $ sudo tcpdump -i lo  -n -nn udp dst portrange 5064-5065
>   02:32:13.408675 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
>   02:32:13.441478 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
>   02:32:13.505696 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
>   02:32:13.632719 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
> So, I suspect the softIoc don’t listen the 5064 port.
> |  netstat -a | grep softIoc
> but I find nothing.
> What I can do now?
> Thanks!
> Sincerely,
> HaveF
stumbled at the first softioc example HaveF
Prev: PROC vs PROC_HOST Doucet, Richard
Next: RE: stumbled at the first softioc example Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: stumbled at the first softioc example HaveF
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
