1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fanout to Sub Records in a Different IOC Causes Core Dump
To: "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>, Andrew Johnson <[email protected]>
Cc: "Poff, Mark A" <[email protected]>
Date: Fri, 10 Oct 2014 10:38:44 +0000
Andrew and Martin (and EPICS community),
After experiencing the repeated crashes and examining a memory dump to the extent necessary to determine where they occurred (according to gdb, it was in camessage.c, line #1344, EPICS v3.14.12.3), I modified the databases to not use fanout records and moved on with my work - and committed the programming sin of not keeping a copy of the failed configuration.  Sure enough, when I tried to recreate the failure scenario yesterday - no crash occurred.  I know the cpp processes were the same (the only changes there were a couple of printf debug statements) but besides modifying the .db files I had also touched the .dbd file and the st.cmd file (we use a customized version) and probably a couple of other things.  The only conclusion I can find is that I’ve missed some small, but significant change I made which somehow contributed to the problem.
I apologize for raising a concern and then not being able to back it up.  The schedule here prohibits me from spending much more time researching this issue, but I will continue to pursue it as time permits and will let you know if I can get the core to recur.
-Mark Poff
-----Original Message-----
Sent: Thursday, October 09, 2014 4:04 PM
To: Poff, Mark A; [email protected]
Subject: Re: Fanout to Sub Records in a Different IOC Causes Core Dump
Hi Mark,
> If you can't, take a look at how much stack space your
> Process1_routine subroutine needs, running out of stack space is one
> possible cause for this kind of strange behaviour in addition to the
> usual kinds of problems. A full stack trace for all threads when the
> crash happens would also help us help you (type 'thread apply all bt'
> in gdb).
Keep in mind that the stack trace could be corrupted. You might want to run with a trivial subroutine for testing.
In addition to that it's always a good idea to write a short test program that calls the subroutine function with some test values. You can run this test program with
valgrind --tool=memcheck <your_test_program>
to see if it is writing to memory it should not write to.
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
Re: Fanout to Sub Records in a Different IOC Causes Core Dump Konrad, Martin
Prev: Re: TCP connection status : drvAsynIPPort Torsten Bögershausen
Next: Re: TCP connection status : drvAsynIPPort J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fanout to Sub Records in a Different IOC Causes Core Dump Konrad, Martin
Next: Re: Fanout to Sub Records in a Different IOC Causes Core Dump Steven
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
