1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fanout to Sub Records in a Different IOC Causes Core Dump
To: "Poff, Mark A" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 9 Oct 2014 20:04:22 +0000
Hi Mark,
> If you can't, take a look at how much stack space your
> Process1_routine subroutine needs, running out of stack space is one
> possible cause for this kind of strange behaviour in addition to the
> usual kinds of problems. A full stack trace for all threads when the
> crash happens would also help us help you (type 'thread apply all bt'
> in gdb).
Keep in mind that the stack trace could be corrupted. You might want to
run with a trivial subroutine for testing.
In addition to that it's always a good idea to write a short test
program that calls the subroutine function with some test values. You
can run this test program with
valgrind --tool=memcheck <your_test_program>
to see if it is writing to memory it should not write to.
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
Re: Fanout to Sub Records in a Different IOC Causes Core Dump Steven
Prev: Re: Fanout to Sub Records in a Different IOC Causes Core Dump Andrew Johnson
Next: Re: MCA and WAN connection Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
