1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MCA and WAN connection
To: [email protected]
Date: Thu, 09 Oct 2014 10:16:00 -1000
Hi both,
if whoever is administering the firewall knows what they're doing
they can just let certain ports through. Our sysadmins do that
here.
HTH,
Maren
On 10/09/14 09:28, Mark Rivers wrote:
Hi Nicholas,
If the server in the US is really not blocked by a firewall then you
should be able to do the following on your client machine in Germany:
- Set the environment variable EPICS_CA_ADDR_LIST to include the IP
address of the server in the US
- You may also need to change some timing parameters.  Read the section
called Configuration  in this document:
http://www.aps.anl.gov/epics/base/R3-14/8-docs/CAref.html
- Run the basic EPICS utilities from EPICS base:
   cainfo ‘pvname’
   getget ‘pvname’
- Launch your MCA client
As Lewis said this would be a dangerous configuration to have the server
not behind a firewall, since anyone could access it.
[mailto:[email protected]] On Behalf Of Nicolas Strauss
Sent: Thursday, October 09, 2014 9:45 AM
Subject: MCA and WAN connection
Dear EPICS support,
I'm trying to access a channel with a PV from a server (located in the
USA and me sitting in Germany) with MCA for Matlab.
For this I'm trying     CH1=mcaopen('pvname')    but without success.
The question for me is, if the reason for this is the firewall of the
server (but should be cutoff) or if I have to add the specific IP of the
server to any file? (library)
Probably problems in the different subnets?
What/where is the parameter which has to be changed?
Thank you for responding my question!
Nicolas
MCA and WAN connection Nicolas Strauss
RE: MCA and WAN connection Mark Rivers
Prev: Re: Fanout to Sub Records in a Different IOC Causes Core Dump Konrad, Martin
Next: RE: Epics Qt at APS: Formal presentation + discussion Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MCA and WAN connection Mark Rivers
Next: PCASpy 0.5.1 Xiaoqiang Wang
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
