1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: MCA and WAN connection
To: "'Nicolas Strauss'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 9 Oct 2014 19:28:25 +0000
Hi Nicholas,
If the server in the US is really not blocked by a firewall then you should be able to do the following on your client machine in Germany:
- Set the environment variable EPICS_CA_ADDR_LIST to include the IP address of the server in the US
- You may also need to change some timing parameters.  Read the section called Configuration  in this document:
http://www.aps.anl.gov/epics/base/R3-14/8-docs/CAref.html
- Run the basic EPICS utilities from EPICS base:
  cainfo ‘pvname’
  getget ‘pvname’
- Launch your MCA client
As Lewis said this would be a dangerous configuration to have the server not behind a firewall, since anyone could access it.
From: [email protected] [mailto:[email protected]] On Behalf Of Nicolas Strauss
Sent: Thursday, October 09, 2014 9:45 AM
To: [email protected]
Subject: MCA and WAN connection
Dear EPICS support,
I'm trying to access a channel with a PV from a server (located in the USA and me sitting in Germany) with MCA for Matlab.
For this I'm trying     CH1=mcaopen('pvname')    but without success.
The question for me is, if the reason for this is the firewall of the server (but should be cutoff) or if I have to add the specific IP of the server to any file? (library)
Probably problems in the different subnets?
What/where is the parameter which has to be changed?
Thank you for responding my question!
Nicolas
Re: MCA and WAN connection Maren Purves
MCA and WAN connection Nicolas Strauss
Prev: RE: TCP connection status : drvAsynIPPort Mark Rivers
Next: Re: Fanout to Sub Records in a Different IOC Causes Core Dump Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: MCA and WAN connection J. Lewis Muir
Next: Re: MCA and WAN connection Maren Purves
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
