Hi Mark,
On 10/07/2014 02:55 PM, Poff, Mark A wrote:
> On the EPICS project here we’ve run into an issue which we believe /may/
> point to a bug with fanout records and CA links - and we’re wondering if
> anybody else has seen this behavior.
I have just checked the 3.14 version of the fanout record, it does
support forward-linking through Channel Access with no problems for me.
If you can replicate your crash using 2 simple IOC databases without any
subroutine records I would be very happy to test your databases and try
to replicate your results.
If you can't, take a look at how much stack space your Process1_routine
subroutine needs, running out of stack space is one possible cause for
this kind of strange behaviour in addition to the usual kinds of
problems. A full stack trace for all threads when the crash happens
would also help us help you (type 'thread apply all bt' in gdb).
- Andrew
- RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
RE: MCA and WAN connection Mark Rivers
Re: Fanout to Sub Records in a Different IOC Causes Core Dump Konrad, Martin
<2014>
<2014>
