1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree [Solved]
To: Heinz Junkes <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 16 Oct 2014 10:29:11 +0000
Hi Heinz,
We are about to release ADCore R2-1, so I would like to get this resolved before we do.
I think I may see the problem.
ADCore/ADApp/commonDriverMakefile contains these lines:
PROD_LIBS_Linux         += hdf5 sz
PROD_SYS_LIBS_Linux     += tiff jpeg xml2 z m
PROD_LIBS_solaris       += hdf5 sz
PROD_SYS_LIBS_solaris   += tiff jpeg z
USR_LDFLAGS_Darwin      += -framework CoreFoundation
PROD_LIBS_Darwin        += hdf5 sz
PROD_SYS_LIBS_Darwin    += tiff jpeg z
Note that on Linux PROD_SYS_LIBS includes xml2, but on Darwin it does not.  This seems like a simple oversight, xml2 is now needed even when not using GraphicsMagick because the HDF5 file writer requires it.
Can you try changing this line:
to this:
PROD_SYS_LIBS_Darwin    += tiff jpeg xml2 z
and removing the line you added to RELEASE_LIBS.local and see if it works?
From: [email protected] [[email protected]] on behalf of Heinz Junkes [[email protected]]
Sent: Thursday, October 16, 2014 5:19 AM
To: EPICS tech-talk
Subject: Re: areadetector,      iocSimDetector can not be started on OS X due to dyld: Symbol not       found: _xmlFree [Solved]
Adding
OP_SYS_LDLIBS += -lxml2
to
RELEASE_LIBS.local
solves the problem.
Heinz
On 16 Oct 2014, at 07:57, Heinz Junkes <[email protected]> wrote:
> Hi Lewis,
> I build it from source.
> Setting the env-vars like this:
> h1:iocSimDetector junkes$ export DYLD_LIBRARY_PATH=/opt/local
> h1:iocSimDetector junkes$ export LD_LIBRARY_PATH=/opt/local
> leads to the same error:
> h1:iocSimDetector junkes$ ../../bin/darwin-x86/simDetectorApp st.cmd.darwin
>  Referenced from: /Users/junkes/PARIS_14/EPICS/support/areaDetector/ADCore/lib/darwin-x86/libNDPlugin.3.14.12.dylib
>  Expected in: flat namespace
> in /Users/junkes/PARIS_14/EPICS/support/areaDetector/ADCore/lib/darwin-x86/libNDPlugin.3.14.12.dylib
> Trace/BPT trap: 5
> Heinz
> On 15 Oct 2014, at 22:59, J. Lewis Muir <[email protected]> wrote:
>> On 10/15/14 3:44 PM, Heinz Junkes wrote:
>>> _xmlFree can be found in /opt/local/libxml2.dylib
>>> 00000000000f2b28 D _xmlFree
>>> Pointing LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to this dir will not
>>> solve the problem:
>>> LD_LIBRARY_PATH=/opt/local/lib
>>> DYLD_LIBRARY_PATH=/opt/local/lib
>>> Any idea?
>> Hi, Heinz.
>> Did you build from source, or are you using the pre-built binary
>> version?  If you're using the pre-built binary, then there is likely
>> something wrong with it since it should include any libraries it needs.
>> Moving beyond that, you said the symbol _xmlFree can be found in
>> /opt/local/libxml2.dylib, but then you set LD_LIBRARY_PATH and
>> DYLD_LIBRARY_PATH to /opt/local/lib.  Note that the path ends in a
>> directory named "lib".  If the libxml2.dylib library is in /opt/local,
>> then you'd need to set LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to
>> /opt/local, not /opt/local/lib.
>> Lewis
areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree J. Lewis Muir
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree [Solved] Heinz Junkes
Prev: Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree [Solved] Heinz Junkes
Next: Re: Usage of the dbNameToAddr funciton ZHANG Zhaohong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Support for hivolt power supply Emma Shepherd
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
