Hi, all The problem has been solved after I changed the dbAddr definition from “struct dbAddr *addr” into “struct daAddr addr”. I am wondering about another thing: if I use the pointer( addr.precord ) together with the dbScanLock and dbScanUnlock to access the fields of the record instead of using the dbGetField and dbPutField, will any negative results happen? If not, does this approach reasonable? Kind regards. ZHANG Zhaohong Beamline Control Group ZhangHeng Road 239, Pudong district, 201204 SSRF, Shanghai, China |
RE: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree [Solved] Mark Rivers
Re: StreamDevice "in" command disturbed by out command Dirk Zimoch
<2014>
Usage of the dbNameToAddr funciton ZHANG Zhaohong
StreamDevice "in" command disturbed by out command haquin
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
