1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Discussion about licenses, copyrights, business, and source code
To: "Emmanuel Mayssat" <[email protected]>, "EPICS mailing list" <[email protected]>
Date: Thu, 23 Oct 2014 06:02:39 +0000
Hi Emmanuel,
I don't want to speak for Vasu, but how I understand his suggestion here is not that there is no copyright on the code or the application, just that it does not need to be displayed in the UI all the time. IMO not displaying the copyright does not mean that the author waived his rights on the SW.
Br, Miha
------ Original Message ------
To: "EPICS mailing list" <[email protected]>
Sent: 22.10.2014 19:29:35
Subject: Discussion about licenses, copyrights, business, and source code
Here is an email about licensing that was sent recently.
1. Yes, you may customize/remove the line at the bottom.
( "Copyright (c) Facility for Rare Isotope Beam (FRIB), Michigan State University ....)
2. Each source file also has license information (GPL). Here is what you may do with it:
    - If you modify a source file, keep the current license info intact, and add your own license info below it.
    - if you are adding a new source file, add your license info at the top (no need to copy FRIB license info).
    - if you are not making any changes to the source file, leave the license info as-is.
Like a book, Software is 'a creative art form' that can be copyrighted/authored.
Should you be able to  take a book, remove the author's name, and potentially put yours on it?
That's exactly what copyrights protect against.
Discussion about licenses, copyrights, business, and source code Emmanuel Mayssat
Prev: RE: Discussion about licenses, copyrights, business, and source code Emmanuel Mayssat
Next: Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Discussion about licenses, copyrights, business, and source code Pete Jemian
Next: RE: Discussion about licenses, copyrights, business, and source code Vuppala, Vasu
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
