On 10/22/2014 05:49 PM, Scott Baily wrote:
On 10/15/2014 7:11 AM, Florian Feldbauer wrote:
Is it possible (e.g. during initialization) to set the DRVH fields via
the asynPortDriver?
At present asynPortDriver does not set DRVH or DRVL. However, I think
this would be a good addition, and easy to add. AsynPortDriver already
has a getBounds function. If you write your writeInt32 function
correctly, you can have it coerce the value to be within range, and
get the same functionality. Unfortunately, the VAL field of the EPICS
channel won't be coerced so users won't know its happening without a
separate readback channel (but you won't write out of range values to
hardware). The initAi and initAo functions already call getBounds, and
convertAi and convertAo use these limits to calculate eslo and eoff.
I see no reason why initLo and InitAo couldn't be modified to adjust
DRVH and DRVL to these values (i.e. set them if they are both 0, or
adjust them if the current values are out of range). Certainly, one
would want to allow the database to specify a tighter range than
device support permits.
Sure. If the database contains a thighter range than the actual hardware
limit, these limits should not be overwritten by the driver/device support.
I will have a look into the init functions to see how it can be
implemented.
Also, you can probably use less than 17 records for the workaround
others were suggesting if you use a couple of dfanout records.
due to our PV naming scheme I would need a individual macro for each
output link of the dfanout record. Concerning
configuration and maintenance I think using one additional ao record for
each Vset record is easier...
Florian
| Dr. Florian Feldbauer |
| Helmholtz-Institut Mainz / |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36 |
| D-55128 Mainz |
| Office: SB1 / 00-213 |
| Phone: (+49)6131 / 39-29605 |
- Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
- AsynPortDriver setting DRVH of ao? Florian Feldbauer
- Re: AsynPortDriver setting DRVH of ao? Scott Baily
Re: Discussion about licenses, copyrights, business, and source code Miha Vitorovic
<2014>
<2014>
