Hi Adam,
What sequence of calls did you make?
You must do the following:
asynUser *pasynUser;
status = pasynCommonSyncIO->connect(port, addr, &pasynUser, drvInfo);
status = pasynCommonSyncIO->disconnectDevice(pasynUser);
It sounds like perhaps you did not call pasynCommonSyncIO->connect first? Note that you CANNOT use a pasynUser that has been created and connected with any other method except pasynCommonSyncIO->connect().
From: [email protected] [[email protected]] on behalf of Adam Bark [[email protected]]
Sent: Thursday, October 23, 2014 10:46 AM
To: Eric Norum
Cc: [email protected]
Subject: Re: Possible to close a TCP/IP socket in asyn?
I probably should have checked the return value from asynCommonSyncIO::disconnectDevice before, I'm getting an asynError and the asynUser::errorMessage is "asynManager::queueRequest no processCallback"
On 23/10/14 16:32, Adam Bark wrote:
I didn't but disabling doesn't appear to make a difference, the local port number doesn't change so it is not reconnecting anyway.
On 23/10/14 15:25, Eric Norum wrote:
Do you have autoconnect disabled?
On Oct 23, 2014, at 5:29 AM, Adam Bark <[email protected]<mailto:[email protected]>> wrote:
Thanks Mark, that certainly clarifies the situation however if I use asynCommonSyncIO::disconnectDevice (the documentation says this calls asynCommon::disconnect) the socket still shows up as "ESTABLISHED" in netstat, at least with 4-22. Am I missing some incantation? I am unclear what should go in drvPvt if I am to use asynCommon::disconnect directly.
Adam.
Eric Norum
- Re: Possible to close a TCP/IP socket in asyn? Adam Bark
- Possible to close a TCP/IP socket in asyn? Adam Bark
- RE: Possible to close a TCP/IP socket in asyn? Mark Rivers
- Re: Possible to close a TCP/IP socket in asyn? Eric Norum
Focus deadlock Specht, Eliot D.
<2014>
<2014>
