Thanks Mark,
I finally figured out that I needed two different asynUsers, one to
connect/disconnect the IP socket, created by asynCommonSyncIO and one to
read data, created by asynOctetSyncIO. In the hope that this might help
someone else out here's is a reasonably minimal example program that I
was testing out ideas in.
#include <stdio.h>
#include <asynOctetSyncIO.h>
#include <asynCommonSyncIO.h>
#include <drvAsynIPPort.h>
int main()
asynUser *commonDataport, *octetDataport;
char data[8000000];
size_t nread;
int eomReason, i;
drvAsynIPPortConfigure("dataport", "acq1001_040:4210", 0, 0, 0);
printf("Connect %d\n", pasynCommonSyncIO->connect("dataport", 0,
&commonDataport, NULL));
printf("Connect octet %d\n", pasynOctetSyncIO->connect(
"dataport", -1, &octetDataport, NULL));
for (i=0; i<20; i++) {
pasynOctetSyncIO->read(octetDataport, data, 8000000, 5.0,
&nread, &eomReason);
printf("read %d bytes\n", nread);
pasynManager->autoConnect(commonDataport, 0);
printf("Disconnect %d\n", pasynCommonSyncIO->disconnectDevice(
commonDataport));
printf("Error: %s\n", commonDataport->errorMessage);
sleep(20);
pasynManager->autoConnect(commonDataport, 1);
pasynCommonSyncIO->connect("dataport", -1, &commonDataport, NULL);
while (1) {
return 0;
This requires asyn and epics base and extensions header files and the
asyn library to build against. I also had to add the path of the
directory containing libasyn.so to my LD_LIBRARY_PATH.
Adam.
On 23/10/14 18:55, Mark Rivers wrote:
Hi Adam,
What sequence of calls did you make?
You must do the following:
asynUser *pasynUser;
status = pasynCommonSyncIO->connect(port, addr, &pasynUser, drvInfo);
status = pasynCommonSyncIO->disconnectDevice(pasynUser);
It sounds like perhaps you did not call pasynCommonSyncIO->connect first? Note that you CANNOT use a pasynUser that has been created and connected with any other method except pasynCommonSyncIO->connect().
From: [email protected] [[email protected]] on behalf of Adam Bark [[email protected]]
Sent: Thursday, October 23, 2014 10:46 AM
To: Eric Norum
Cc: [email protected]
Subject: Re: Possible to close a TCP/IP socket in asyn?
I probably should have checked the return value from asynCommonSyncIO::disconnectDevice before, I'm getting an asynError and the asynUser::errorMessage is "asynManager::queueRequest no processCallback"
On 23/10/14 16:32, Adam Bark wrote:
I didn't but disabling doesn't appear to make a difference, the local port number doesn't change so it is not reconnecting anyway.
On 23/10/14 15:25, Eric Norum wrote:
Do you have autoconnect disabled?
On Oct 23, 2014, at 5:29 AM, Adam Bark <[email protected]<mailto:[email protected]>> wrote:
Thanks Mark, that certainly clarifies the situation however if I use asynCommonSyncIO::disconnectDevice (the documentation says this calls asynCommon::disconnect) the socket still shows up as "ESTABLISHED" in netstat, at least with 4-22. Am I missing some incantation? I am unclear what should go in drvPvt if I am to use asynCommon::disconnect directly.
Adam.
Eric Norum
- Possible to close a TCP/IP socket in asyn? Adam Bark
- RE: Possible to close a TCP/IP socket in asyn? Mark Rivers
- Re: Possible to close a TCP/IP socket in asyn? Adam Bark
- Re: Possible to close a TCP/IP socket in asyn? Eric Norum
Re: compile on Windows XP with MinGW Jani Hakala
Re: Focus deadlock Specht, Eliot D.
<2014>
<2014>
