1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector and ADRoper; view files in imageJ
To: "'zunbeltz'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 10 Nov 2014 15:30:30 +0000
> The funny thing now is that imageJ opens a white canvas. As soon as I open the brightness dialogue the image is how fine.
That is normal behavior with 16-bit images.  For some reason ImageJ always gets the initial brightness and contrast wrong for 16-bit images. But as you said if you open the brightness dialog (Control+Shift+C) it then displays OK.
-----Original Message-----
Sent: Monday, November 10, 2014 9:23 AM
To: Mark Rivers; [email protected]
Subject: Re: areaDetector and ADRoper; view files in imageJ
Dear Mark,
Thanks. It was my fault because a typo in this environment variable.
Thanks.
Zunbeltz
al., 2014.eko azaren 10a 13:50(e)an, Mark Rivers igorleak idatzi zuen:
> Hi Zunbeltz,
> Have you looked at the Troubleshooting section in the areaDetector Viewers documentation?
> http://cars.uchicago.edu/software/epics/areaDetectorViewers.html#Troubleshooting
> The EPICS areaDetector ImageJ viewer creates a diagnostic log window that probably has error messages in it.
> I suspect that your problem is that you need to set the environment variable EPICS_CA_MAX_ARRAY_BYTES to a value that is at least as large as the biggest image you want to transport over Channel Access.  In your screen shots the images are 1024x1024 16-bit.  That means EPICS_CA_MAX_ARRAY_BYTES needs to be at least 2MB=20897152.  I would recommend setting it to 10000000 in case you use some larger cameras as well.
> The EPICS_CA_MAX_ARRAY_BYTES environment variable needs to be set on both the Windows machine running the EPICS IOC and on the client machine that is running ImageJ.
> Mark
> From: [email protected] [[email protected]] on behalf of zunbeltz [[email protected]]
> Sent: Monday, November 10, 2014 4:58 AM
> To: [email protected]
> Subject: areaDetector and ADRoper; view files in imageJ
> Dear all,
> I got running areaDetector with a PI-MAX camera using the ADRoper driver.
> In my setup the camera is controlled by the ioc server in a windows machine.
> Use MEMD to acquire the photos from a remote linux machine.
> I manage to connect imagej to the acquired image; but it is completely
> black ( all the bytes 0).
> The configuration used can be seen in the attached fiels.
> I try to change the file format from SPE to TIFF (16 bit and 8 bit) but
> I always get a 16 bit black image in imageJ.
> (I have installed the SPE plugin).
> Any idea where can I look?
> Best regards,
> Zunbeltz
> Dr. Zunbeltz Izaola
> Accelerator Physics Group
> ESS-Bilbao
Dr. Zunbeltz Izaola
ESS-Bilbao
areaDetector and ADRoper; view files in imageJ zunbeltz
RE: areaDetector and ADRoper; view files in imageJ Mark Rivers
Re: areaDetector and ADRoper; view files in imageJ zunbeltz
Prev: Re: areaDetector and ADRoper; view files in imageJ zunbeltz
Next: Browser based EPICS GUI Alex Wallace
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
