1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS locks up, debugging suggestions
To: <[email protected]>
Date: Wed, 12 Nov 2014 11:18:02 +0100
Hi Geoff,
Since I'm new to CSS and Java I'm interested in debugging techniques
others have found successful.  For example, I was unprepared for not
being able to see all the threads as with a C or python program.
Do you mean that you can't see all the threads in the output from top(1) ?
First thing to do is find the pid of the VM itself. You can get this from ps(1) or using the jps tool [1] that comes with the JDK.
This main process is the one that top(1) will show by default. However if you type 'H' (upper case, not lower case) top will switch to showing threads. You will then see one line for each Java thread. This might allow you to identify particular threads that are busy.
Another JDK tool, jstack [2], will give you a thread dump showing what each thread is doing. Unfortunately the process IDs in the jstack output (nid=0xNNNN) are in hex, whereas in jps/top they're decimal :-)
The other thing that jstack might show you, at the bottom of its output, is that there's a deadlock.
Obviously the user has to leave the hanging program running for you to be able to get in there and (try to) diagnose the problem. At Diamond, we developed a simple bash script for users to run that would run jstack a few times and save the output somewhere for us to have a look at.
[1] https://docs.oracle.com/javase/8/docs/technotes/tools/unix/jps.html
[2] https://docs.oracle.com/javase/8/docs/technotes/tools/unix/jstack.html
Rich
Richard Fearn
Senior Software Engineer
Integrated Control Systems division
European Spallation Source ESS AB
[email protected]
Re: CSS locks up, debugging suggestions Kasemir, Kay
CSS locks up, debugging suggestions Geoff Savage
Prev: RE: Browser based EPICS GUI tom.cobb
Next: Re: CSS locks up, debugging suggestions Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CSS locks up, debugging suggestions Geoff Savage
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
