1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compile qtdm
To: Mark Rivers <[email protected]>, "'Emmanuel Mayssat'" <[email protected]>
Cc: Mezger Anton Christian <[email protected]>, EPICS mailing list <[email protected]>
Date: Sat, 15 Nov 2014 19:43:22 +0800
Hi Mark, Emmanuel and all,
Thanks for your help, finally I made it. I'd like to share my experience.
I think the previous failed reason was:
1: On my linux system (Linux Mint Qiana, x86_64, kernel 3.13.0) Qt 4.8.6 (/usr/lib/x86_64-linux-gnu/qt4) and 5.1.1 (/opt/Android/Qt5.1.1/5.1.1/gcc_64/) was installed; 2: The 'qmake' command (/usr/bin/qmake) is 4.8.6 by default, which would be called first before I redefined the PATH value;
Thanks to Mark and Emmanuel's message, I clearly redefined the PATH value to let 'qmake' be definitely the 5.1.1 version, i.e. export PATH=PATH=/opt/Android/Qt5.1.1/5.1.1/gcc_64/bin:/bin/:/usr/bin/:/usr/sbin, and then everything went smoothly.
Tong
On 11/15/2014 02:49 AM, Mark Rivers wrote:
I had similar problems the other day when I built caQtDM on Linux.
Anton helped me a lot.
I have appended a message that includes the complete trail of
communications with Anton.  I have also attached a shell script I
created to define all of the necessary environment variables.
I think my most important 2 mistakes were:
- Not defining QTBASE, which I then defined as:
QTBASE=/usr/local/caQtDM/3-8-5/caQtDM_Binaries
- Not using the top-level build script, caQtDM_BuildAll.  I was just
using qmake and make, which did not work.
[mailto:[email protected]] *On Behalf Of *Emmanuel Mayssat
*Sent:* Friday, November 14, 2014 12:35 PM
*To:* Tong Zhang
*Cc:* Mezger Anton Christian; EPICS mailing list
*Subject:* RE: compile qtdm
Tong Zhang,
I can certainly help you.
Difficult to say what exactly is the problem without the error message.
To start, I would just guess that you environment is not set correctly.
Are you on Linux?
Note that  QtDM requires a few environment variables to be set to start
and run correctly.
What are your settings for QTDM_LIBINSTALL, QTDM_RPATH, and LD_LIBRARY_PATH?
In the tutorial you are following, my installation paths were
/home/local/epics                # Home directory of the epics user
+-- base
     +-- <base.version>           # Base version is 3.14.12.4
         +-- bin/linux-x86_64
         +-- lib/linux-x86_64
+-- extensions
     +-- <base.version>           # Extensions compiled against this base version
         +-- src                  # Where the source for EPICS extensions is installed
         +-- bin/linux-x86_64     # Where the extension binary files are installed
+-- extras                       # Non-EPICS base and non-EPICS extensions
     +-- <base.version>           # Version the source was compiled against
         +-- bin/linux-x86_64     # Where the binary files are installed
In the tutorial, I installed caQtDM in the extras/... directories as it is not
an EPICS extension (i.e. doesn't use the configure directory which is part of
the EPICS build system)
I hope this help.
If it doesn't, send the error message and the first few lines of
./caQtDM_BuildAll
Emmanuel Mayssat
http://www.epicsqt.org
Date: Fri, 14 Nov 2014 14:44:18 +0800
To:[email protected] <mailto:[email protected]>
Subject: compile qtdm
Hi Emayssat,
I came cross your caQtDM wiki page, it is really a great job. I'm
working on the development for FEL facility control applications, and I
have experience about C++/QT, so your qtdm is a nice tool for me to
choose. However, I failed to compile the source, is complains the
qtcontrols lib when linking, my qt version is 4.8.6, could you please
help me out?
Thanks!
Tong Zhang
Free-electron Laser Department,
Shanghai Institute of Applied Physics (SINAP), CAS
2019 Jialuo Road, Shanghai 201800, China
Office: +86-021-3919-4269
Mobile: +86-185-1628-3148
RE: compile qtdm Emmanuel Mayssat
Prev: Re: Browser based EPICS GUI Alex Wallace
Next: RELATED TO GRAPH priya tiwari
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: compile qtdm Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
