On 11/24/14 13:28, Eric Norum wrote:
How about using an scalcout record to format the number using %.6f and
then a protocol entry with %5c ?
Or a gensub or asub to generate the whole string?
On Nov 24, 2014, at 2:54 PM, Mark Rivers <[email protected]
<mailto:[email protected]>> wrote:
Dirk and all,
I have a device that requires a command of the following format:
ratei NNNNN ml/h
where NNNNN is a number that is exactly 5 characters long including
the decimal point. For example if the rate is 9 then:
ratei 9.000 ml/h
If the rate is 10 then the string must be
ratei 10.00 ml/h
If one sends 10.000 (six characters) the command is rejected.
Is there a way to achieve this with streamDevice?
I can’t use the field width flag, since that just sets a minimum field
width. I need to set a maximum field width.
I realize this is a ridiculous behavior for a device, but I need to
deal with it.
Maren
- streamDevice output format question Mark Rivers
- Re: streamDevice output format question Eric Norum
Re: Small bug in caget Andrew Johnson
<2014>
RE: streamDevice output format question Mark Rivers
<2014>
