1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: usage of CALC
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 27 Nov 2014 16:42:49 +0100
Hi Liang,
There's a few things that do not make sense.
1. You have a longin *input* record that is connected to a protocol that only writes to the device. Where do you expect this record to get its value from?
2. Your calcout record is invalid: spaces are not allowed in record names.
3. The input A of your calcout points to itself: every time it processes, it will multiply the previous value with 20 (according to your CALC expression) and send it to the hardware. This is probably not what you intend to do.
Assuming that you have your protocol right, and that the RPS record should hold your number, you should be thinking along the lines of
record(longout,"RPS")  # relative distance
    field(DESC, "move relative")
    field(EGU,  "um")
    field(FLNK, "RPS_write PP")
record(calcout,"RPS_write")
    field(DTYP,"stream")
    field(OUT,"@devKohzuAries.proto RPS $(PORT) $(A)")
    field(CALC,"A*20")
    field(INPA,"RPS")
HTH,
~Ralph
On 27/11/2014 15:52, 梁雅翔 wrote:
     Sorry to bother you, I have some trouble which pullze me some time, could you please give me some advice.
     I am trying to control a step motor.
     Now I want to set a number(60) to pv(um distance), send the number*20(60*20=1200) to device. I think CALC would be useful. I could not understand CALC well though I have RRM 3-14.
     The following code is what I do.
Thanks!
*******devKohzuAries.db
record(longin,"RPS")  # send to device
     field(DESC, "move relativly")
     field(DTYP, "stream")
     field(INP,  "@devKohzuAries.proto RPS $(PORT) $(A)")
     field(FLNK,"um distance")
record(calcout,"um distance")
     field(CALC,"A*20")
     field(INPA,"um distance.VAL")
********  devKohzuAries.proto
RPS{
     out "\x02RPS1/5/%d/0";
Liang YX
Institute of High Energy Physics
Chinese Academy of Sciences
P. O. Box 918, 100049 Beijing
R. P. China
Tel: 0086-0188235977-603
Email: [email protected]
usage of CALC 梁雅翔
Prev: Sorenson SGA DC power supplies Linda.Pratt
Next: Re: Defining enums to express state? Ryan Pierce
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: usage of CALC 梁雅翔
Next: Re: usage of CALC Dirk Zimoch
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
