1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Darwin SHRLIB_VERSION build error: multiple target patterns
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 10 Dec 2014 17:27:09 -0600
Hello, Tech-Talkers.
On Darwin, with EPICS Base 3.14.12.4, setting SHRLIB_VERSION makes my
library build fail with the following error:
/opt/epics-3.14.12.4/configure/RULES_BUILD:290: *** multiple target patterns.  Stop.
Here's how to reproduce the problem:
1. $ mkdir example
2. $ cd example
3. $ makeBaseApp.pl -t example example
4. Add the line
     SHRLIB_VERSION += 0.1.0
   below the line "# ADD MACRO DEFINITIONS AFTER THIS LINE" in
   exampleApp/src/Makefile:
   $ vi exampleApp/src/Makefile
5. make
This produces the following output:
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./configure install
perl /opt/epics-3.14.12.4/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
mkdir O.Common
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install
perl /opt/epics-3.14.12.4/bin/darwin-x86/convertRelease.pl checkRelease
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./exampleApp install
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./src install
perl /opt/epics-3.14.12.4/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../..
mkdir O.Common
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install
make[2]: *** [install.darwin-x86] Error 2
make[1]: *** [src.install] Error 2
make: *** [exampleApp.install] Error 2
Am I doing something wrong, or is this broken?
Environment:
* Processor: 2.3 GHz Intel Core i7 (4 cores)
* Memory: 8 GB
* OS: Mac OS X 10.10.1
* EPICS Base 3.14.12.4 + Known Problems patches up to 2014-04-07
  Architecture: darwin-x86
  Architecture Class: x86_64
Thank you!
Lewis
Re: Darwin SHRLIB_VERSION build error: multiple target patterns Andrew Johnson
Prev: RE: Different behavior on dbdToRecordTypeH - include guard Kim, Kukhee
Next: Re: Darwin SHRLIB_VERSION build error: multiple target patterns Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: dxp R3-4 released Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
